Page 2 of 3
Re: Omnitec Selex Pal retrofit
Posted: Wed Feb 03, 2021 5:51 pm
by repauli1
It has an in/out Neutral. Also they have an earthground which has a terminal soldered to casing.
Posted: Wed Feb 03, 2021 6:38 pm
by ashesman
I cant find any information to say that you would need to connect it. As long as you are not using a neutral and all current is returning through the three phase wires, just leave the neutral terminals open. Definitely dont short them together. You could earth one end of them but I really dont see that gaining much.
Posted: Thu Feb 11, 2021 9:33 am
by repauli1
Couple more updates, I have the DMM servo drives all wired up, next up wire in MPG pendant (10 switches, one mpg dial, resolution dials.
Posted: Thu Feb 11, 2021 10:52 am
Do you have a properly sized line reactor feeding the DYN4 drives in there some where
I see 3 encoder cables hooked up. What are those for? Hand wheels?
Nice clean work!
Posted: Thu Feb 11, 2021 10:14 pm
by repauli1
Yes, those are the single phase for control voltage, the large 16am 3phase are on the other side. Those 3 cables are for the 1616 expander boards. Total of 90 I/O
Posted: Thu Feb 11, 2021 10:15 pm
by repauli1
I just reread your post, Line reactor is on order!
Posted: Thu Feb 11, 2021 10:43 pm
Sorry. I didn't zoom in and mistook the IO expansion pirate for encoder connectors.
Posted: Fri Feb 12, 2021 3:11 pm
by ashesman
Nice work! I like the way you have stacked the ADD1616s. I am not really a fan of how they mount on top of the Oak myself! What is the PCB tucked away under the servo drives? 90 IO is quite a lot is it mostly related to the tool changers?
Posted: Fri Feb 12, 2021 8:07 pm
by repauli1
There is an 8 tool rotary, plus a 9 vdrill block, with solenoids to push drill down and engage. Also have 10 buttons with lighted feedback. Relay cards behind the drives.
Posted: Tue Jan 04, 2022 11:39 pm
by repauli1
Update, Centroid Oak conversion is in final assembly, after bench testing complete system (control panel on table)
