Omnitec Selex Pal retrofit
repauli1
Re: Omnitec Selex Pal retrofit
Post by repauli1 »
It has an in/out Neutral. Also they have an earthground which has a terminal soldered to casing.
ashesman
Post by ashesman »
I cant find any information to say that you would need to connect it. As long as you are not using a neutral and all current is returning through the three phase wires, just leave the neutral terminals open. Definitely dont short them together. You could earth one end of them but I really dont see that gaining much.
repauli1
Post by repauli1 »
Couple more updates, I have the DMM servo drives all wired up, next up wire in MPG pendant (10 switches, one mpg dial, resolution dials.
Do you have a properly sized line reactor feeding the DYN4 drives in there some where
I see 3 encoder cables hooked up. What are those for? Hand wheels?
Nice clean work!
repauli1
Post by repauli1 »
Yes, those are the single phase for control voltage, the large 16am 3phase are on the other side. Those 3 cables are for the 1616 expander boards. Total of 90 I/O
repauli1
Post by repauli1 »
I just reread your post, Line reactor is on order!
Sorry. I didn't zoom in and mistook the IO expansion pirate for encoder connectors.
ashesman
Post by ashesman »
Nice work! I like the way you have stacked the ADD1616s. I am not really a fan of how they mount on top of the Oak myself! What is the PCB tucked away under the servo drives? 90 IO is quite a lot is it mostly related to the tool changers?
repauli1
Post by repauli1 »
There is an 8 tool rotary, plus a 9 vdrill block, with solenoids to push drill down and engage. Also have 10 buttons with lighted feedback. Relay cards behind the drives.
repauli1
Post by repauli1 »
Update, Centroid Oak conversion is in final assembly, after bench testing complete system (control panel on table)
