Rapids
Posted: Sun Jan 03, 2021 12:30 am
by occustoms
Can i setup rapid overide using inputs, I know plc has to be edited. But is it possible to only overide the rapid moves and not regular feedrate?
Re: Rapids
Posted: Sun Jan 03, 2021 1:05 am
by cncsnw
No.
Feedrate override always applies to feedrate moves. You can select whether or not it applies to rapid and jogging moves, but you cannot prevent it from applying to feedrate moves except by disabling it altogether.
Re: Rapids
Posted: Sun Jan 03, 2021 5:01 pm
by occustoms
cncsnw wrote: ↑Sun Jan 03, 2021 1:05 am
No.
So thier is no way to isolate the goo moves alone from feedrate??
Re: Rapids
Posted: Sun Jan 03, 2021 5:26 pm
by cncsnw
No.
If you want to slow down all your rapids, you can go to Machine Configuration -> Jog Parameters table and reduce the numbers in the Max Rate column.
Re: Rapids
Posted: Sun Jan 03, 2021 8:06 pm
by occustoms
cncsnw wrote: ↑Sun Jan 03, 2021 5:26 pm
No.
was wanting to use a knob with inputs. As i already machined the plate for it lol. Anyway of making a custom macro and implementing that into the inputs ? to only change G00? Or is it a problem with the centroid controller not being able to? Maybe pm me your number cause it looks like your the guy ima gonna have to pay to get some stuff done for my plc for this one anyway. And would like a way to figure out a way to do rapids. Gotta be a way if a 30+ year old controls can do i would think a centroid could find a way.
