Page 1 of 2
Geneva umbrella wiring
Posted: Sat Jan 02, 2021 3:45 am
by occustoms
I cant seem to find the default wiring for using a 1616 on oak of where they want the sensors to and motors wired too? I have a fadal geneva drive with 2 110v dc motors. one for slide and one for turret. searched and havent seen anything. also need it for the drawbar and solenoids for air etc.
Re: Geneva umbrella wiring
Posted: Sat Jan 02, 2021 8:42 am
occustoms wrote: ↑Sat Jan 02, 2021 3:45 am
Take a look at the attached OAK Schematic.
See if helps. You have to use the Inputs and Outputs as outlined in the schematic in order to use the corresponding PLC.
Posted: Sat Jan 02, 2021 3:29 pm
by occustoms
Awesome thank you!
Posted: Sat Jan 02, 2021 4:19 pm
occustoms wrote: ↑Sat Jan 02, 2021 3:29 pm
Awesome thank you!
Hope it helps...
Posted: Sat Jan 02, 2021 7:33 pm
by occustoms
It does, only thing i have that is not listed is the oreintation arm. i have a solenoid that activates an arm with a small bearing that locks the spindle pulley from moving like when a m19 is activated.
So will i have to just wire to output on 1616 and have some custom plc for that?
I also have a atc fault switch that if the tool doesnt release during pick up or put down on carousel, that switch is activated and e-stops machine. should i just put this in line with estop circuit? or is their a better way?
Posted: Sat Jan 02, 2021 7:36 pm
Does your orient arm have a sensor to let the control know when it in?
Does your machine have sensors for drawbar release and drawbar lock?
Posted: Sat Jan 02, 2021 8:16 pm
by occustoms
martyscncgarage wrote: ↑Sat Jan 02, 2021 7:36 pm
No on orint arm, and no on the drawbar. (factory fadal dont have it)
i can add a simple sensor and bracket for drawbar, but cant for orint, atleast not very easily.
i also dont have a seperate home for carousel, only out or in.
Can i just jumper the 1616 with home and carousel out?
Posted: Sat Jan 02, 2021 8:21 pm
by cncsnw
What Centroid usually means by "carousel home" is a rotational position, to tell if it is at or near tool 1.
As a rule, even though it appears on Centroid's schematic, such a sensor is really unnecessary on a Centroid control because the software will keep track of the carousel position from day to day. There is no need to home the carousel on power-up.
Posted: Sat Jan 02, 2021 8:32 pm
by occustoms
cncsnw wrote: ↑Sat Jan 02, 2021 8:21 pm
thank you that clears up one part.
so do i need to add a sensor for clamped and unclamped?
also what about the orient complete?
Posted: Sat Jan 02, 2021 9:13 pm
by occustoms
Well im blind it does have orient spindle sensor. Still need to know about clamped and unclamped sensor being needed?
