Page 1 of 2
MPU11/GPIO4D using encoder expansion board not all of info
Posted: Thu Dec 31, 2020 9:32 pm
by Poorboy
Has anyone used the encoder expansion board? I have it hooked up and powered on with a solid 1 on the led display.
the goal was to use the first input for my manual knee axis.
how are the encoders assigned?
Re: MPU11/GPIO4D using encoder expansion board not alot of info of info
Posted: Thu Dec 31, 2020 9:33 pm
by Poorboy
I also have scales on all my other axis.
Re: MPU11/GPIO4D using encoder expansion board not all of info
Posted: Thu Dec 31, 2020 11:16 pm
by tblough
Encexp encoders start at 16. Refer to 15.3.138 in the CNC12 v4.14 manual.
Posted: Fri Jan 01, 2021 1:03 pm
by Poorboy
thanks trying it now.
I must of read that section 10 and didn't see the last line!
kind of surprising that little bit of info wouldn't be in the expansion card PDF
Posted: Sat Jan 02, 2021 9:41 am
Poorboy wrote: Fri Jan 01, 2021 1:03 pm thanks trying it now.
Let us know if it resolves your issue.
Re: MPU11/GPIO4D using encoder expansion board not a lot of info
Posted: Sat Jan 02, 2021 4:33 pm
by Poorboy
still not reading the encoder.
I know this encoder works. I plugged it into one of the MPU11 board ports and I see the values change.
I have the axis labeled M for manual and I have parameter 312 set to 16.
did the required restart and still not reading. any ideas
Posted: Sat Jan 02, 2021 4:46 pm
Can you please post a current fresh report?
Posted: Sat Jan 02, 2021 7:24 pm
by cncsnw
Are you using wired input (gray cable), or optical fibers?
Do you have the "Wired Input" jumper on the ENCEXP board installed or removed, as appropriate?
Do you have your encoder plugged into the first DE9 port (the one adjacent to the fiber optic receptacles)?
Posted: Sat Jan 02, 2021 9:12 pm
by Poorboy
Yes
I have the wired pin not jumpered because I'm using fiber cables.
The encoder is plugged in the first DB9 port. I also tried using other ports as wel,l changing the parameters as required.
I do have a solid 1 on the LED display.
Posted: Sat Jan 02, 2021 9:13 pm
by Poorboy
The db9 port is also labeled port 1
