new project
chessie
Re: new project
Post by chessie »
got it
thanks
chessie
Re: new project
Post by chessie »
the supply to the rectifier is 220v 3 phase , i only have 240v single phase can this be configured differently or will i need another power supply.
i read the sd3 manual and there was a line about matching supply with the motor voltage which according to the servo nameplate is 260v so my question is how can i supply the sd3 with power. if i need a 300v dc power supply what sort of current will i require.
Also the vfd for the spindle motor ( control techniques unidrive sp2401) this needs a 415v 3ph supply which i don't have . so if i replaced this with a 220v vfd and a normal 3ph motor star delta motor will this be a problem with the m400 control?
im happy with the rest of the conversion i just need a bit of help regarding the servo drive and what eventually to do with the spindle
thanks
Re: new project
According to Centroid [and this was news to me, as I have never worked in the 50Hz world] 3-phase input is required.
Apparently the DC supply will be unsteady, and drive response unreliable, if you run their rectifier on single phase 50Hz.
On the spindle side: you should be okay with any spindle drive (VFD) and motor combination that is capable of orienting the spindle for tool changes.
Re: new project
As an FYI:
Rectified 240VAC gives you 339VDC
AC Voltage X 1.414
As Marc mentions:
There is some question about whether or not your machine will run on single phase 240VDC 50HZ. Centroid says no. Had it been 60HZ they say its a different story. Assume you have 50HZ power?
You may be in a pickle...
chessie
Re: new project
Post by chessie »
thanks marty/marc
yes its 50hz here
so the spindle drive/motor shouldn't be an issue then if i ended up replacing it. with something like this Yaskawa V1000 IP20 4kW 230V 1ph to 3ph AC Inverter Drive
i guess the sd3 comes as part of the m400 package and its that or nothing ?
so if i want to use it
is it a case of buying a phase converter to run all or part of the machine,
or using a different rectifier 240v 50hz input to supply the dc voltage to power the sd3?
is the 50hz issue with the centroid rectifier , as the sd3 is dc ?
Re: new project
chessie wrote: Fri Apr 16, 2021 3:19 pm thanks marty/marc
yes its 50hz here
Sounds to me like you need a well balanced digital phase converter.
do see if your spindle motor can be rewired to low voltage then you only have the VFD to worry about. Remember you'll need a VFD with spindle orient capability.
Sorry, we all learned something from this. 50hz frequency is the culprit.
polaraligned
Re: new project
Post by polaraligned »
I am going to assume that Centroid is thinking you are just using 2 legs of that rectifier input and putting single phase into the existing rectifier.
DC is DC and the only variable should be how much ripple is in the DC. If you use the proper rectifier circuit, you will get clean DC output regardless of the input being single phase, 50 or 60 hz or three phase. Three phase is actually easier to to get clean DC from with less ripple. If you need DC and that is the only problem, you just need to change the rectifier and filter setup.
Re: new project
I'm not crossing Centroid's expertise/experience. If the original poster wants to give it a go, it's up to him.
Re: new project
I did not get a detailed explanation.
My guess is that the ripple is excessive with the lower input frequency. It does seem to me that could be addressed with a larger capacitor, but I am not an electrical engineer.
With the control you have, the SD3 is the only realistic option for driving the motors you have. You can certainly supply a different rectifier, though.
chessie
Re: new project
Post by chessie »
polaraligned wrote: Fri Apr 16, 2021 5:55 pm I am going to assume that Centroid is thinking you are just using 2 legs of that rectifier input and putting single phase into the existing rectifier.
this is what was confusing me as well , DC is Dc , if it needs to be clean then that's the issue, as marc said i need the sd3 to be able to keep the control so i have no option than to give it a go .
i will now see what is available to buy or get built to produce a clean around 300v dc supply from 240v 50hz .
the question is in order to supply the sd3 ,with the servos already pictured ,how much power do i need to be aiming for ?
ideal voltage /current
thanks for all your help
