**RESOLVED**Axis enables not working w/ updated Mach3 plugin
Locked
RallyRat
Post by RallyRat »
I installed Mach3 plugin v1.10 today and found that I can no longer enable my servo drives.
The Ajax Enables brain is functioning as before (I did not reinstall any brains). Modbus Outputs 351,352, and 353 are shown equal to 1 when the drives are to be enabled, but there is no voltage present at the respective axis 1,2, and 3 EN outputs. I also tried changing the X enable lobe terminator to a single output bit, Mod351-D0, with no change.
Any thoughts on what might have changed since, I believe, v1.04?
Will
diycncscott
Re: Axis enables not working with updated Mach3 plugin
Post by diycncscott »
Hello Will,
Please send your Ajaxlog.txt and MachAjax.xml file to tech@ajaxcnc.com -both files can be found in the Ajax subdirectory of you Mach install.
Also, please be sure your power off everything off after an update. (don't just reboot the PC)
RallyRat
Post by RallyRat »
I looked through Ajaxlog.txt and discovered the new axis/drive mappings. Everything is now working as it ought to after reconfiguring.
Thanks!
Locked
