Tool Check Spindle Dwell
Posted: Fri Dec 11, 2020 2:58 pm
I currently have a dwell time programmed into my M3 macro to allow 5 seconds for the spindle to spool up, which works as expected except when resuming from a tool check.
When I resume, motion starts immediately after the spindle is energized. If I forget to crank down the feedrate override before I hit cycle start, things get ugly. I'm aware of the VFD "at speed" hardwire option (though I'm not sure if that would work any better in this situation) however that's not physically possible for my install at the moment.
Doesn't resume run through the code up the tool check point including executing the M3 command? Why no dwell?
Thanks.
Thanks.
