This is for an ALL-IN-ONE board.
Maybe someone could direct me to documentation showing dip switch location numbers, what each switch does, and the corresponding settings.
I must be blind, but I can't find it anywhere.
Dip Switch settings
Re: Dip Switch settings
Here's the main document http://www.centroidcnc.com/downloads/ce ... manual.pdf
All the manuals can be found here: https://www.centroidcnc.com/centroid_di ... nuals.html
- CNC Control System Serial Number: 929110276
Thanks, but I have all of those. Either I'm over looking the dip switch settings or there non-existent in the documentation. Now before anyone notes that the manual shows the dip switch, the one shown has to do with servo amp setting. Nothing on the others. Who knows the information could be on the board or cover for the board, but since the DC1 is sitting on top I can't see if it's there or not.
The only two that matter are the servo amp settings and the limit switch override.
The other two banks of DIP switches are for configuring the analog output and the analog input. They matter only if you need to use something other than 0-10VDC.
See the hardware manual that should be appended to the end of the installation manual.
Search for "SW3" and "Analog Output Range Selection", and "SW2" and "Analog Input Range Selection".
Yes, that’s exactly what I need. I need to set it to +/-10v. This would allow me to reverse direction. I’ll look again to see if I overlooked the information.
There are charts on page 7 and 8 of the "user guide" that is tacked on the end of the document linked above.
