All in one CNC11
Re: All in one CNC11
Tim wrote:I would like to add 3 physical switches. Power On (Cycle Start?), Feed Rate Up, Feed Rate Down, Please can you help out and give an indication of any costs.
I can provide the PLC programming, and if necessary phone/e-mail/forum technical support, at my usual service rate of USD $60/hr. It is likely that you would need between one and two hours.
There is no additional software or hardware you need to purchase on the Centroid side. You just need to purchase three normally-open pushbuttons and some suitable wiring supplies, then wire those buttons between your DC power supply and any available PLC inputs on your Allin1DC unit. Exactly how you do that (as in, which wires you connect where) will depend on your particular installation.
kcarpenter1986
Post by kcarpenter1986 »
at 800 its a bit expensive on top of the 2500+ already spent..... and seeing as all he wants is these 3 buttons adding in to the software
the all in one has got lots of inputs that he is not using. seams like it should be easy to map these to cycleStart, FeenUP and FeedDown
is it likley that getting someone to edit code this is going to be more expensive than the 800 for jog panel?
kcarpenter1986 wrote: Mon Sep 28, 2020 7:57 pm at 800 its a bit expensive on top of the 2500+ already spent..... and seeing as all he wants is these 3 buttons adding in to the software
Marc offered, send him a PM
kcarpenter1986
this sound like a good option to me.
I all ready have the buttons available and atm I have connected them to the low, mid and high gear (as tims mill is not using these inputs)
And if i press the buttons I can see the inputs going on off in the inputs screen.
I will get tim to pm
Tim
CNC Control System Serial Number: A900872
Post by Tim »
I look forward to hearing from Kyle.
kcarpenter1986
Update on this one.
The reason he did by the jog panel is the cost.
We considered going down the programming route but again this seamed very costly for what we wanted to achieve (adding 3 buttons)
So we came up with a very cheep solution
we got a 3 pedal usb foot switch
https://www.ebay.co.uk/itm/USB-Triple-A ... SwyWddDIc6
this device allows you to program a press of the foot switch to do a series of keyboard presses
broke it open and fixed wires to the sensors inside that go to our switches on the front panel and set the device to mimic the keyboad shortcuts
nice simple code free solution
could be useful for someone else
