Tim wrote:I would like to add 3 physical switches. Power On (Cycle Start?), Feed Rate Up, Feed Rate Down, Please can you help out and give an indication of any costs.
I can provide the PLC programming, and if necessary phone/e-mail/forum technical support, at my usual service rate of USD $60/hr. It is likely that you would need between one and two hours.
There is no additional software or hardware you need to purchase on the Centroid side. You just need to purchase three normally-open pushbuttons and some suitable wiring supplies, then wire those buttons between your DC power supply and any available PLC inputs on your Allin1DC unit. Exactly how you do that (as in, which wires you connect where) will depend on your particular installation.
kcarpenter1986 wrote: ↑Mon Sep 28, 2020 7:57 pm
at 800 its a bit expensive on top of the 2500+ already spent..... and seeing as all he wants is these 3 buttons adding in to the software
the all in one has got lots of inputs that he is not using. seams like it should be easy to map these to cycleStart, FeenUP and FeedDown
is it likley that getting someone to edit code this is going to be more expensive than the 800 for jog panel?
Marc offered, send him a PM
