MPUCOMP error window
- CNC Control System Serial Number: A900856
When compilling the PLC source and it contains a error I get just a quick pop up of the blue window. Is there a error file made or a way to have the pop up window stay on. to trouble shoot the error.
Re: MPUCOMP error window
Run mpucomp from a CMD window with the command line mpucomp <filename.src> mpu.plc and you should see all the output from the compiler including errors if they exist.
