Renishaw MP11 Probe Setup
BodeRacing
CNC Control System Serial Number: 102849
Re: Renishaw MP11 Probe Setup
Post by BodeRacing »
Aly-Tek wrote: Mon Nov 02, 2020 9:27 pm
Hi BodeRacing, That's the same setup I'm trying to install. But it looks like you've only used 8 pins and the Renishaw OMI-2T has 13. Any chance you could share the wires and pinouts you used and any install notes I need to be aware of? It would be very much appreciated ;)
Many thanks,
Stephen
My comments:
- - I need to make some changes. Atrump did not enable tool touch off detect so I did not use it. I did not think it existed in the control, but it does. Parameter was not enabled. The folks on this board helped me figure it out. I need to add it and haven't had the chance yet.
- - I should of spent the money to buy an I/O expansion module. I still might. So I kind of cheated. I would of done more of it in the PLC if I had more outputs available.
- - I did not take the time to read the PLC programming instruction manual. So I kinda winged it on past experience. Not sure the programming is what it should be but it works.
- - I used AUX buttons to enable the spindle and tool touch off probes. See the PLC program for details.
- - JB is the junction box I added at the probe connector.
See if my stuff makes any sense to you...............
report_1116170498_2020-10-27_19-08-14.zip
(2.33 MiB) Downloaded 33 times
Renishaw Probe Wiring rev May 15 2020.pdf
(39.01 KiB) Downloaded 41 times
Drawings PDF Version rev May 27 2 2020.pdf
(7.87 MiB) Downloaded 43 times
Aly-Tek
CNC Control System Serial Number: A900869
Post by Aly-Tek »
Thanks for the details BodeRacing :) I'm still in the process of my initial retrofit and post in here when it's all fitted and tested ;)
Many Thanks
Stephen @ Aly-Tek :D
