IF MpgMacro1PD_PD THEN SV_SYS_MACRO = 1
IF MpgMacro2PD_PD THEN SV_SYS_MACRO = 2
IF MpgMacro3PD_PD THEN SV_SYS_MACRO = 3
IF MpgMacro4PD_PD THEN SV_SYS_MACRO = 4
IF (SV_SYS_MACRO > 0) && !(MpgMacro1PD_PD || MpgMacro2PD_PD || MpgMacro3PD_PD || MpgMacro4PD_PD)
THEN SV_SYS_MACRO = 0
Could this not be replaced with the simpler version, or am I missing some subtlety of how the PLC process code?
IF True_M THEN SV_SYS_MACRO = 0
Thanks Marc. It actually seems to work better than the original; sometimes I used to have to push my button firing the macro a couple of times before it would execute. Now it seems to fire every time.
