Bench Test Allin1DC
Reeltime273
Bench Test Allin1DC
Post by Reeltime273 »
Hello Everyone,
I was finally able to sit down and start the bench test process, Allin1Dc all wired up, downloaded the Centroid CNC 12 software and PLC program, I uploaded the Allin1DC_Centroid_Standard default program. Got to Chapter 4 to the 'Unlock Demo Code' screen with my Software unlock Sheet in front of me, it looks like I have CNC7 and CNC10 demo locking codes, nothing about CNC12, in which I downloaded. Do I have to download CNC10 or 11 first and then run the upgrade? Not sure on where to go from this point?
Mark
Re: Bench Test Allin1DC
Enter the code(s) you received. CNC12 uses the same codes as CNC7 (v5.23 and later); CNC10; and CNC11.
Reeltime273
cncsnw,
Thanks, instructions were a little unclear. Moving forward now. Does anyone know a quick way to toggle between the LAN connector to the ALLin1DC and the Internet? I was trying to create an additional LAN icon in my network connection under setting, then I can go into and just make a quick choice. How is everyone else doing this?
Mark
Reeltime273
Got it figured out.
Mark
Reeltime273 wrote: Sat Jul 18, 2020 7:44 am cncsnw,
Mark
Once CNC12 makes the CNC PC I.P. address static, it's used for one thing, communicating to All in One DC. Add another network card if you want a second Ethernet port or use a USB wifi adapter.
