V2XT Gear Selector Prox Switch (Resolved)
- CNC Control System Serial Number: A900588
With my gear selector in the high speed position, the
signal to input 13 on my All-in1-DC should be red showing
an open contact. Mine is green. The input does change
state when I cycle the gear lever.
Back on 1-8-2014, cncsnw recommended adding 512 to
Par 178 to invert the states. That doesn’t seem to work
for me. Is there another parameter I should be looking at?
Thanks, Scott
Thanks, Scott
Re: V2XT Gear Selector Prox Switch
It depends on what PLC program you are using.
We cannot tell without a Report.
However, if it is a reasonably standard one that is less than five years old, then it probably uses Ctrl-Alt-i (on the Alt-i PLC Diagnostic display) to invert inputs, instead of using bits of Parameter 178.
Scott, ALWAYS provide a FRESH report when you ask a question or even follow up question. The report contains all the machines parameters and how you have them set.Daniels Precision wrote: ↑Sat Jul 11, 2020 4:22 pm With my gear selector in the high speed position, the
Thanks, Scott
Thanks Marty and cncsnw,
Here is a copy of my report along with some photos of my machine.
Scott
https://photos.google.com/album/AF1QipM ... KdskM9Ti5j
Scott
- report_0717171799_2020-07-13_16-25-43.zip
- (3.29 MiB) Downloaded 127 times
You have to SHARE the album and create a link. Your link above does not work for anyone but you most likelyDaniels Precision wrote: ↑Mon Jul 13, 2020 5:21 pm Thanks Marty and cncsnw,
Scott
Your PLC program uses inversions on the Alt-i display. It does not use Parameter 178.
Worked. Nice clean wiring job!Daniels Precision wrote: ↑Mon Jul 13, 2020 10:31 pm https://photos.google.com/share/AF1QipO ... VURUJESHNn
Marc is suggesting you invert the input.
Go into your diagnostic screen. Alt+i to toggle it on and off
Go to the input. There will be a descriptor, middle of the screen under the last row of "LEDs" so you make sure you are on the right one.
Press Ctrl+Alt+i to invert the input, there will be a bar over the LEd when inverted.
See if that works
That did it!
Thanks Marty & Marc for your help.
