Posts: 9914 Joined: Tue Mar 28, 2017 12:01 pm
Post
by martyscncgarage » Fri Dec 18, 2020 10:35 am
Gixer wrote: ↑ Fri Dec 18, 2020 6:56 am
I`ve upgraded to ultimate now but my wmpg has stopped working if i press the mpg button on the vcp it doesnt light up i`ve checked the parameters and they seem to be ok.
all there is on the wmpg handset is the signal strength and battery.
any ideas
Please post a fresh report.
Go into Parameters and make sure they are set correctly for the WMPG.
Set Tech Bulletin 313
https://www.centroidcnc.com/dealersuppo ... ds/313.pdf
Unplug the transciever from the PC and move it to a different port if your settings are correct.
Gixer
Posts: 45 Joined: Tue Jun 30, 2020 3:18 pm
CNC Control System Serial Number: 0324202376
Post
by Gixer » Fri Dec 18, 2020 1:20 pm
This helped a lot cheers marty Wmpg is working again.
I`ll get a fresh report done tomorrow.
Post
by martyscncgarage » Fri Dec 18, 2020 1:22 pm
Gixer wrote: ↑ Fri Dec 18, 2020 1:20 pm
Cool.
What setting did you find was off?
Gixer
Post
by Gixer » Fri Dec 18, 2020 2:28 pm
Had to change Para 218 - Value 7 - 3 Axis Mill/Router.
Then Software restart.
Now just waiting for the prob to arrive Which says should be here Monday.
Paul.
Gixer
Post
by Gixer » Wed Dec 23, 2020 11:22 am
Hi .
OK i got my probe all up and running managed to do 1 full pass on something it did`nt come out to good but ok for first try but now it goes for about 5 mm and just cancels i`ve tried a few different ways but just seems to cancel on it`s own out of the blue.
Any help would be appreciated .
btw it probes ok for hole centring and edge finding i just seem to have the problem in digitizing .
Paul
report_0008DC111213-0324202376_2020-12-23_13-43-22.zip
(5.99 MiB) Downloaded 137 times
Post
by martyscncgarage » Wed Dec 23, 2020 12:40 pm
Message log:
(You can find the logs in the F7 Utility Menu)
(1) 12-23-2020 8:22:32 199 CNC Started
(1) 12-23-2020 8:22:36 CNC12-D Mill v4.16
(4) 12-23-2020 8:22:37 2099 Message Cleared
(1) 12-23-2020 8:22:37 412 MPG1 encoder error
(1) 12-23-2020 8:22:49 Created Weekly Report
(1) 12-23-2020 8:23:34 412 MPG1 encoder error
(1) 12-23-2020 8:23:34 407 Z+ limit (#50006) tripped
(1) 12-23-2020 8:23:55 407 X- limit (#50001) tripped
(1) 12-23-2020 8:24:04 407 Y+ limit (#50004) tripped
(4) 12-23-2020 8:24:29 907 X axis travel exceeded
(4) 12-23-2020 8:24:34 907 X axis travel exceeded
(1) 12-23-2020 8:24:40 MPG moving too fast
(1) 12-23-2020 8:32:23 453 Jogging while probe detected
(1) 12-23-2020 8:32:24 453 Jogging while probe detected
(1) 12-23-2020 8:32:26 453 Jogging while probe detected
(1) 12-23-2020 8:32:37 453 Jogging while probe detected
(1) 12-23-2020 8:32:46 453 Jogging while probe detected
(1) 12-23-2020 8:32:49 453 Jogging while probe detected
(1) 12-23-2020 8:33:06 453 Jogging while probe detected
(4) 12-23-2020 8:47:20 918 Probe unable to detect surface
(4) 12-23-2020 8:47:45 918 Probe unable to detect surface
(4) 12-23-2020 9:01:26 918 Probe unable to detect surface
(4) 12-23-2020 9:02:24 918 Probe unable to detect surface
(4) 12-23-2020 9:02:50 916 Unexpected probe contact
(4) 12-23-2020 9:12:21 918 Probe unable to detect surface
(4) 12-23-2020 9:13:10 918 Probe unable to detect surface
(4) 12-23-2020 9:14:34 4032 Reset Cleared
(1) 12-23-2020 9:15:52 204 Exiting CNC...Normal Exit (66)
(1) 12-23-2020 9:19:37 199 CNC Started
(4) 12-23-2020 9:19:40 9039 Software Exited, Cycle E-Stop/Reset to Continue
(1) 12-23-2020 9:19:41 CNC12-D Mill v4.16
(4) 12-23-2020 9:19:42 2099 Message Cleared
(4) 12-23-2020 9:19:43 2099 Message Cleared
(4) 12-23-2020 9:24:36 918 Probe unable to detect surface
(4) 12-23-2020 9:25:32 918 Probe unable to detect surface
(4) 12-23-2020 9:27:58 918 Probe unable to detect surface
(4) 12-23-2020 9:31:04 918 Probe unable to detect surface
(4) 12-23-2020 9:39:23 918 Probe unable to detect surface
(4) 12-23-2020 9:47:15 918 Probe unable to detect surface
(1) 12-23-2020 9:58:30 453 Jogging while probe detected
(1) 12-23-2020 9:58:31 453 Jogging while probe detected
(1) 12-23-2020 9:58:32 453 Jogging while probe detected
(1) 12-23-2020 9:58:51 453 Jogging while probe detected
(1) 12-23-2020 9:58:52 453 Jogging while probe detected
(4) 12-23-2020 9:59:52 918 Probe unable to detect surface
(4) 12-23-2020 10:03:50 918 Probe unable to detect surface
(4) 12-23-2020 10:04:43 918 Probe unable to detect surface
(1) 12-23-2020 10:16:21 Error: Travel outside of grid.
(4) 12-23-2020 10:19:45 907 X axis travel exceeded
(4) 12-23-2020 10:21:58 907 X axis travel exceeded
(4) 12-23-2020 10:21:59 907 X axis travel exceeded
(1) 12-23-2020 10:23:11 MPG moving too fast
(1) 12-23-2020 10:27:33 Error: Travel outside of grid.
(1) 12-23-2020 10:28:51 Error: Travel outside of grid.
(1) 12-23-2020 10:35:45 453 Jogging while probe detected
(1) 12-23-2020 10:36:54 453 Jogging while probe detected
(1) 12-23-2020 10:37:09 453 Jogging while probe detected
(1) 12-23-2020 10:37:10 453 Jogging while probe detected
(1) 12-23-2020 10:37:11 453 Jogging while probe detected
(1) 12-23-2020 10:37:12 453 Jogging while probe detected
(1) 12-23-2020 10:37:13 453 Jogging while probe detected
(1) 12-23-2020 10:37:14 453 Jogging while probe detected
(1) 12-23-2020 10:37:22 453 Jogging while probe detected
(1) 12-23-2020 10:37:27 453 Jogging while probe detected
(1) 12-23-2020 10:37:31 453 Jogging while probe detected
(1) 12-23-2020 10:37:33 453 Jogging while probe detected
(1) 12-23-2020 10:39:17 453 Jogging while probe detected
(4) 12-23-2020 10:41:04 9033 Reset Initiated, Press Reset to Clear
(4) 12-23-2020 10:41:05 4032 Reset Cleared
(1) 12-23-2020 10:42:43 Error: Travel outside of grid.
(4) 12-23-2020 10:43:34 9033 Reset Initiated, Press Reset to Clear
(4) 12-23-2020 10:43:54 4032 Reset Cleared
(4) 12-23-2020 12:46:16 918 Probe unable to detect surface
(1) 12-23-2020 12:49:58 406 Emergency stop detected
(1) 12-23-2020 13:43:22 Creating report...
What probe do you have connected to the control?
Post
by martyscncgarage » Wed Dec 23, 2020 12:46 pm
Have you seen the Centroid Digitizing videos on YouTube? They might help. I don't have enough experience to offer any good advice. The times I did test it, it worked well for me.
Gixer
Post
by Gixer » Wed Dec 23, 2020 2:13 pm
It`s the KP-3.
Yes i`ve checked the videos and searched the forum i did some more tests on the other digi programs and worked ok but the one i want to use only works for about 5mm then cancels it`s the digi Grid one thats giving me a problem.
Paul
Gixer
Post
by Gixer » Thu Dec 24, 2020 3:18 pm
OK so i managed to get the KP-3 running properly today and did my first full pass on grid setting.
So now hopefully i will be able to get back to normal now as i`ve missed using my mill.
Post
by martyscncgarage » Thu Dec 24, 2020 5:38 pm
Excellent!
