DRILLING CYCLES NOT WORKING
I suspect that I am missing something obvious but I'm just not seeing it right now. The customer is telling me that the drilling and tapping cycles are not working. Does anyone see any reason that drilling or tapping would not work? Everything else works fine. Attached is a drilling file that he is using (Kiduah.cnc). Machine is a Shizuoka AN-S originally retrofitted in 2010 with a MPU11/DC3IO then updated in 2017 with an ALLIN1DC. Thanks in advance.
- report_0215171689_2020-06-09_01-34-30.zip
- (255.35 KiB) Downloaded 122 times
- KIDUAH.CNC
- (386 Bytes) Downloaded 96 times
Re: DRILLING CYCLES NOT WORKING
create the drilling cycle using Intercon run it and then and compare the Intercon G code to your file
There is no X or Y on the G83 line.
Either change the post to include XY coordinates on each drilling line, or change Machine Parameter 2 to a value of 2.
Thanks to both Marc and Keith. I knew I was missing something fundamental.
Marc, You were right on the money. Thanks.
