***RESOLVED*** Motor work in continue mode very slow
Locked
pablocnc
CNC Control System Serial Number: 511100195
Post by pablocnc »
Please my cnc machine has installed with mpu11 system and DC3IOB, when i am working in my machine is very fast and have a good speed in the motors x, y and z, but when i want move the motors with a jog mode contine (my keyboard) in mach 3, the motors move very slow, Some people of ajax can help me... please... my problem is the config plugin?. Ajax recommended Kp=1 Ki=.004 Kd=3..
AjaxTech
Re: Motor work in continue mode very slow
Post by AjaxTech »
What is the value on your Feed Rate Override?
pablocnc
Post by pablocnc »
my value in feedrate is 200 but with my keyboard the speed is 18 or 20 mm/min, when i run the g code, the speed is 200mm/min, this value is to move in fast feedrate. what is my problem?.. How can program my machine to a good work?. only this configuration and my retrofit is ok.
diycncscott
Post by diycncscott »
Pablo,
Please send us the machajax.xml file located in c:\mach3\ajax so we can see what your slow jog rate is set to.
If you are unaware of the slow jog rate setting, use Config->Config Plugins ->AjaxPlugin
pablocnc
Post by pablocnc »
thank you for you response, I could repair the problem, in following days i send you the file mach, congratulation, the retrofit is very good.
AjaxTech
Post by AjaxTech »
pablocnc,
Has this issue been resolved?
pablocnc
Post by pablocnc »
yes, thanks for you help..
Locked
