Hi:
Can a Laptop be used with an ALLINONE/MACH3/CENTROID?
Lawrence
**RESOLVED** Laptop be used with an ALLINONE/MACH3/CENTROID?
Re: Laptop be used with an ALLINONE/MACH3/CENTROID?
Hello,
Laptops themselves aren't a problem. Just make sure to disable power saving and CPU throttling.
Another issue you may run into is the bloatware installed in laptops - I'd strongly suggest a clean
OS install. Keep in mind, any type of real-time anti-virus or malware should be disabled to prevent
interference with data transfer to and from the MPU11
