Hey i am doing a system test on my mill and not passing the encoder index pulse too close to home i am using estun motor how can i change the position
of the encoder pulse index to home. i am also getting software travel limit are set incorrectly. Here is my report attach
system test help
- CNC Control System Serial Number: A900662
system test help
- Starting system test 4.docx
Version Information
$Id: systest.cnc,v 1.1.1.1 2006/01/05 14:30:21 kdennison Exp $
System is NOT configured for ATC
; Checking travel limits and home set
Travel limits set and machine is homed.
; Starting home switch testing
Homing axis 1 minus
1 / 8 turn distance is 0.0492
7 / 8 turn distance is 0.3444
full turn distance is 0.3936
Off switch| error | home | error | differnce
-0.2263 0.0000 -0.0000 0.0000 0.2263
Off switch Max Min Difference
-0.2263 -0.2263 0.0000
home posiiton Max Min Difference
-0.0000 -0.0000 0.0000
Homing axis 1 plus
28.2979 0.0000 27.9482 0.0000 0.3497
28.2979 28.2979 0.0000
27.9482 27.9482 0.0000
*** FAILURE Home position too close to encoder index pulse
Axis has both minus and plus home switches
-Distance between home positions is 27.9482
-Distance between travel limits is 28.2323
-Difference between distances is -0.2841
*** FAILURE Travel limits set incorrectly
Homing axis 2 minus
1 / 8 turn distance is 0.0493
7 / 8 turn distance is 0.3448
full turn distance is 0.3941
-17.6719 0.0000 -17.3408 0.0000 0.3311
-17.6719 -17.6719 0.0000
-17.3408 -17.3408 0.0000
Homing axis 2 plus
0.1832 0.0000 0.0000 0.0000 0.1832
0.1832 0.1832 0.0000
-Distance between home positions is 17.3408
-Distance between travel limits is 17.6185
-Difference between distances is -0.2777
Homing axis 3 minus
-19.1220 0.0000 -18.9156 0.0000 0.2064
-19.1220 -19.1220 0.0000
-18.9156 -18.9156 0.0000
Homing axis 3 plus
0.1444 0.0000 0.0001 0.0000 0.1443
0.1444 0.1444 0.0000
0.0001 0.0001 0.0000
-Distance between home positions is 18.9157
-Distance between travel limits is 19.0565
-Difference between distances is -0.1408
Finished testing home/limit switches
*** FAILED SYSTEM TEST ***
Version Information
Homing axis 1 minus
Homing axis 1 plus
Homing axis 2 minus
Homing axis 2 plus
Homing axis 3 minus
Homing axis 3 plus
*** FAILED SYSTEM TEST *** - (15.09 KiB) Downloaded 66 times
Re: system test help
Hey guys i pass the system test the index pulse was too close to home i move the switch
Usually, unbelting and turning the servo motor a half turn and rebelting will do it as well as moving the switch.owgstrength wrote: ↑Sat Feb 23, 2019 9:10 am Hey guys i pass the system test the index pulse was too close to home i move the switch
Glad you got it going
