Hi,
Last weekend started to install my new ALLIN1DC module.
I can't control any input/output.
All I can see is DF led out and Display LED error # 1.
Did I something wrong?
Regards,
gabo
**RESOLVED** AllIn1DC DF LED OUT
Re: AllIn1DC DF LED OUT
Are you running Mach or CNC11?
What sections of the installation manual have you successfully completed? It is important that you complete each section before attempting to continue to the next.
If your LED is a solid "1" - that is the normal operating status for the drive.
Are you lube and spindle faults wired? All encoders wired?
As the installation manual states, any fault -lube, spindle, encoder will prevent the drive fault relay from energizing.
- CNC Control System Serial Number: 214110102
I'm running Mach.
Lube,Spindler faulds was wired and encoder too, but didn't have the brain for them.
I did the brains and right now is working.
DF LED turn on when press RESET button on mach screen.
Thanks for ou help!
Regards,
gabo
Thanks for ou help!
Regards,
gabo
