**RESOLVED** Compiling a PLC program -AnthonyOhio
Locked
AnthonyOhio
CNC Control System Serial Number: 929100262
More than 1 system
Post by AnthonyOhio »
None of the changes made to the plc are working. it is as if there were no changes made.
I checked the plc, the changes are there.
I compiled it 2 more times, shutting down everything and rebooting. No change.
Any thoughts?
-Anthony
diycncscott
Re: Compiling a PLC program -AnthonyOhio
Post by diycncscott »
Anthony,
You're probably not specifying the correct output file.
Make sure you are compiling from c:\cncm
command line should be:
mpucomp sourcefilename.src mpu.plc
I think the name of you source is something along the lines of anthonyboss.src?
It is important that you always name the output file to be mpu.plc as that is what the software loads.
In addition, be sure to power off and restart after compiling.
AnthonyOhio
More than 1 system
Got it!
Everything is working great so far.
Love the new control with the CNC11 software!
Thank you, Scott.
-Anthony
Locked
