Hi Scott :
Attached is a pdf document on a VS mini inverter..Can you help in providing wiring diagram for connection into DC103B running Mach3.
Spindle is an Elte , 18000 rpm, 2.2kw
Your help would be greatly appreciated.
Jason
VS Mini Inverter
VS Mini Inverter
- TOE-S606-10.10 VS mini C Series Instructions Standard (Spec A&E).pdf
- (1.6 MiB) Downloaded 237 times
Re: VS Mini Inverter
Hello,
I sent you an email with a wiring diagram on Friday, 2/18. Did you receive it?
