Looking for a source for XL Keyless Timing pulleys. .5" bore (or boreable) 1" wide.
I remember reading about keyless pulleys, that clamp down to the shaft, but for the life of me, I can't find the post.
Thanks in advance for ideas.
Keyless Timing Pulley
Re: Keyless Timing Pulley
Marty...
Are you sure you are looking for XL? They are light duty and I have never seen them advertised over 1/2" wide.
That said, here is my source: https://shop.polybelt.com/main.sc
They have XL bar stock and flanges, but no clamping pulleys.
Usually pulleys with Quick Disconnect (clamping) style housings only come in the L and larger sizes. Misumi has some in metric sizes, however. https://us.misumi-ec.com/vona2/detail/1 ... 797%3a%3ac
System you are after is called Taperlock. You can buy taperlock bushes as well & bore your pulley to match.
Regards,
Michael
Regards,
Michael
It's for the turret drive on an EMCO 140 lathe. Belts clearly says 200XL. Emcos do have their little quirks. I could take pulley stock and make it.as well.Gary Campbell wrote: ↑Tue Nov 13, 2018 8:29 pm Marty...
You could also look at Fenner keyless bushings. McMaster sells them (even though they refuse to tell you the brand, they are Fenner) https://www.mcmaster.com/screw-clamp-bushings The "Quick-Grip Screw-Clamp Bushings" at the bottom of the page are Fenner Trantorque Minis.
Thank you Tom!tblough wrote: ↑Wed Nov 14, 2018 10:21 am You could also look at Fenner keyless bushings. McMaster sells them (even though they refuse to tell you the brand, they are Fenner) https://www.mcmaster.com/screw-clamp-bushings The "Quick-Grip Screw-Clamp Bushings" at the bottom of the page are Fenner Trantorque Minis.
