Control # 8121 cnc engine lathe T-15
I was wondering how to edit the default date on the lathe.
I do not know how to do this I could use some help.
Also I pressed the edit button on the lathe and could not exit it, only turning off the machine did it.
Thank you in advance!
reseting date and exiting eddit mode
- CNC Control System Serial Number: 102978, 8121, REV233
- report.zip
- (36.31 KiB) Downloaded 87 times
- CNC Control System Serial Number: K2019,K1110
Re: reseting date and exiting eddit mode
As it boots up initial screen press delete key to enter cmos on motherboard check date setting if its off you cmos battery is probable going dead
Thank You,
I Will check that.
I Will check that.
