**RESOLVED** Soft limits
I tried to set the soft limits as explained in Mach 3. They don't seem to work. Are they disabled in Ajax? Does the plugin require a differant proceedure?
Re: Soft limits
Hi Captain,
Soft limits work through Mach. The plugin doesn't change anything.
You have to enable soft limits by clicking on the button (a green border lights up around the button)
If it won't let you enable soft limits, it will issue a warning in the ticker... what does it say?
Re: Soft limits
I had no idea there was a button on the screen.
Thank you
Thank you
