**RESOLVED** can not get past ajaxplugin
each time i try to go to ajaxplugin, so i can change stop on encoder error, plugin control goes away and reset lights with emergency mode active comes on. what do think may be my problem ?. thanks
Re: can not get past ajaxplugin
Have you ever been able to open the plugin?
Yes, plugin seems to open, but some areas seem to be unavailable to me. I have an HP comp./ with more than min. requirement to operate mach or ?. Could something be loaded wrong . Thanks for info and input.
cncman41
cncman41
Make sure that you have at least .NET 2 or higher installed. You can get .NET 3.5 from here:
http://download.microsoft.com/download/ ... etfx35.exe
Thanks Scott, that helped, and also downloaded adobe reader 9.5 I believe, together they cured the problem with mach3 installs and opperation.
Hi,
Thanks for the update. Let us know if you have any more questions.
