Hardinge HC CNC Turret Lathe
Re: Hardinge HC CNC Turret Lathe
martyscncgarage wrote: Thu Dec 02, 2021 3:51 pm
rabreu1969 wrote: Fri Nov 26, 2021 7:08 pm E209F4F6-6E63-420B-BF0A-00C65A255446.jpegThere’s a vfd already there. My cabinet is 220V single phase. I found that I can disconnect the power cord from where the 3 phase comes in where the power to the cabinet is and plug it directly into my 220v outlet. This has a 5hp motor
GS2 can't do full 5hp, so you are stuck with the converter feeding the VFD and using single phase on the control.
Unless you upgrade the VFD to a single phase compatible VFD. (Not inexpensive but not terrible either)
First post a fresh report, F7 Utility, F7 Create Report then upload it here. Click on Full Editor and Preview. Under the box where you write the post there are two tabs, one options and one attachments. Click on Attachments.
Also, it would be good for you to do a little video. Upload it to YouTube as unlisted and share a YouTube video link here.
rabreu1969 wrote:New question. When I press "tool check" the carriage does not go to home position. It does the opposite. Stops right before the spindle and comes towards operator side. How do I change this so when I press "tool check" it goes to home position?
Change the G28 return point, under Part Setup -> WCS, back to Z0 X0.
See http://www.cncsnw.com/LatheNotes.htm and scroll to the bottom of the page.
rabreu1969
CNC Control System Serial Number: 2188
Post by rabreu1969 »
That's what I did. The control is connected to single phase 220V and the motor and VFD are connected to the phase converter. All works great. It' to bad you cant switch from air power for the turret n collet closer to an electric actuator setup. Compressor runs a lot.
rabreu1969
Thanks for the tip on how to reset the tool check position.
