Feature Request - SSV
Re: Feature Request - SSV
Thank you for the explanation.
Is there anything you do not know about Centroid ?
If you look at most of the stock Centroid PLC programs, Marc is the one who wrote them!
thank you thank you thank you
When I see the result, how good it turned out...it's just great.
I don't want to praise myself but.....it was good to annoy you
As you know, I'm just the operator who needs the parts... and tells you what needs to be improved or should be improved...
Can you please show me/us where to insert your PLC?
Danke Danke Danke Uwe
Du bist der beste
Stephan
Du bist der beste
Stephan
Stephan,
if you have TeamViewer on your CNC PC, I can do this in a few minutes.
But I hope someone with better knowledge than me is making a version with sine curve acceleration in the PLC, to make the feature independent from servo tunning...
Here is my test which is a bit bigger than Uwe's.
80mm part 400 mm long Steel
thanks again Uwe
thanks again Uwe
- WhatsApp Video 2024-05-27 at 18.12.18.mp4
- (2.75 MiB) Downloaded 12 times
Fine that my offline PLC compilation and SSV worked for you.
I'm still hoping that at some point you'll feel like adding a pecking command to G71.
As I said, thanks again for SSV
Greetings Stephan
Greetings Stephan
Yes, of course Fusion can.
For parts where I don't have to take exact measurements you can use Fusion...
But for example the shaft there I have 2 bearing fits and with things like
that it's easier to change something quickly in the code.
I always have to measure when it comes to 0.01...0.02...0.03 mm.
At Fusion Code I'm always busy searching but in G71, it takes seconds to change and you can jump to line G70 straight away.
