Hey Guys!
Been having a bit of an issue for awhile now with probed data and cutting finish in the ports. I think its related to the A-axis. There is usually about .03" ridge where the ports meet on the roof and floor. Where the 2 halves meet is fine at the sides, its just the vertical.
Now I'm really having an issue while trying to probe a combustion chamber. None of the data lines up at all in mastercam. When I tilt the machine, the splines I get dont overlap by close to .04". Hoping you can give a little insight. Wondering if the rotary center is out of wack or what is going on.
Wade
Probed data not lining up in Mastercam
- CNC Control System Serial Number: 10690
- report.txt
- (475.21 KiB) Downloaded 10 times
- report.zip
- (290.73 KiB) Downloaded 10 times
Re: Probed data not lining up in Mastercam
i moved this post out of the Acorn forum
Hello Wade,
John Cowher Here from Centroid. Please contact George Ensminger at 814-553-3298 email gensminger@centroidcnc.com and get a conversation started regarding your problem with A axis
Also Steve Boucher 814-353-9290 ext 105 sboucher@centroidcnc.com
We may be able to provide some direction, or otherwise may need to send someone on site.
Please contact George or Steve rather than using the forum for support.
Best Regards,
John
Best Regards,
John
