M-15 repair or replace motherboard, or upgrade?
nop
Post by nop »
Hi. I have a M-15 controller whose battery leaked during a period of disuse (COVID), and unfortunately it may have taken the motherboard with it. The EPROM looks fine, it's just the area around the battery that may be damaged. It looks like it will be necessary to remove the board, clean the area around the battery, and solder on a new socket to determine whether the board survived the leak. Was this a popular motherboard, and if so, are replacements available? Or does it make sense to replace the entire controller with a newer unit?
Re: M-15 repair or replace motherboard, or upgrade?
There were four or five different motherboards used in different M15 models over the years.
However, regardless of which motherboard you have, the answer is probably that no replacements are available, and if your current one is damaged beyond repair, you had best look at retiring the M15 console and upgrading the controller (e.g. with an Allin1DC system).
nop
Post by nop »
Hi cncsnw. You helped me replace the Z motor on this machine a couple years ago. Thanks again for that! https://centroidcncforum.com/viewtopic. ... 41&p=37330
I found the list of motherboards on your website. I'll pull ours to get a better look. If it's beyond repair, do you know if replacing it is simply a matter of plugging the controller components into a new board and transferring the ROM?
I will also check out the Allin1DC system. Thanks, again.
There is no "ROM" that can or should be transferred.
If you find a working replacement motherboard of the same model, you would just install it in the console; plug the CPU7P3 board into the PC104 bus connector; and plug in the hard drive and other computer peripherals. All of the information about your machine setups is on the hard drive. Depending on the control model, your hard drive might be a traditional 3-1/2" IDE hard drive; or it might be a compact flash memory card in an IDE adapter; or it might be a compact flash memory card in a SATA adapter; or it might be a SATA solid-state hard drive.
