Is the KP-3 the "replacement" for the previous versions of probes offered by Centroid?
We originally had a Dp4D early DSP version of the DP4, however the DSP ceased to work eventually and I disabled it in the control, using it as a standard kinematic probe.
The DP-4 has since died an ugly death and is resting In pieces due to a crash.
I have a cheapo probe that I use for rough setup, however I am looking to potentially begin some digitizing again and I do not like the cheapo for that.
Additionally does the KP-3 for legacy systems include the inverter circuit in the cable / connector so the tool touch probe can be used along with the KP-3 on the same input?
John
KP-3 probe for older probe replacement
- CNC Control System Serial Number: 10583
Re: KP-3 probe for older probe replacement
hello! yes and yes. KP3 is a replacement for DP4 and is what i recommend.
when ordering select "Kp3 for oak/allin1dc/mpu11"
https://www.centroidcnc.com/centroid_di ... probe.html
Thanks Keith!
Looks like I will have to dust off the "Learning how to digitize a port with the E320 and TRT-32" again. Haven't done one in at least 10 years.
John
John
