Hi, I'm a beginner I need advice - I'm going to connect this servo-driver Junma SJDE 08APA OY GPIO4D with board. studying the installation manuals, but somehow I do not understand something I'm missing .. Mismatch and the number of outlets on the driver vs. Junma. gpio4d. As I wrote I am a beginner and I need a clue.
idelání for me is a simple scheme with the number of outlets (4, 6, 8, etc. ..) and visual connection with gpio4d unit.
There is a manual for servo driver :
http://epo.cz/stahovani-souboru/doc_dow ... zenim.html
page 38 - electrical outputs PULS, SIGN, CLR, ... 7 wires
And here is the manual for gpio4d :
http://www.ajaxcnc.com/tech/downloads/m ... nstall.pdf
page 26 - I need to explain here Analog outs (2 wires), ENABLE, FAULT
As I understand it -
on left gpio4d-------------on right driver Junma
pin ENABLE -------------- pin /S ON it is ok?
pin ANALOG +out ------- pin ?
pin ANALOG -out ------- pin ?
The question is, is it connected? it is thus possible to control the motors ?
GPIO4D and Junma
Re: GPIO4D and Junma
It appears those drives are position controllers: they accept digital signals telling them to move a certain amount, and they are responsible for getting there.
There is no reasonable way to use those drives with an Ajax or Centroid control.
The GPIO4D provides an analog (+/- 10V) velocity or torque reference signal. It works with drives that are speed or torque controllers, not position controllers.
Sorry.
Sorry.
Thanks, maybe it was a stupid idea, but you'd better ask.
Which drivers do I connect to GPIO4D? And what servo motors? Rather I am interested in the way connections, pins ..,
I searched a while, GPIO4D can therefore operate with outputs +10 V /-10V only drives for large motors, yes?
For example, http://www.intermtnfuse.com/images/ABB/ ... -Guide.pdf - it can connect with GPIO4D and attach more powerful engine?
it is suitable for motion control axes X, Y, Z as the horizontal milling machine ?
Ajtakrajta,
The MPU11/GPIO4D systems and run 3rd party drives that accept -10/+10 analog input and the motor and or drive has a quadrature differential encoder signal to feed back to the MPU11.
The link to the drive you posted does accept an analog signal. As long as the motor you use has a differential quadrature encoder it will work with an MPU11/GPIO4D system.
Yes the MPU11/GPIO4D system will run an X, Y, & Z horizontal milling machine.
The ACS55 drive in your second post looks like a general-purpose inverter, not a servo drive.
You need a servo drive.
Try the Yaskawa Sigma II (SGDH) or Sigma V (SGDV) series.
