This is my first cnc build so any help is greatly appreciated. I'm trying to figure out the vfd connections.
I'm using a Fuji FRN0012C2S-2U. From what I am understanding in the manual pin 11 would be for the analog gnd, and pin 12 would be analog out. Also I think 30B and 30C would be the fault relay. I'm confused where to connect for the fault reset. I'm posting a link to the fuji manual, hope it works.
https://www.google.com/url?sa=t&source= ... tKloJb0RG5
Fuji VFD connections
Re: Fuji VFD connections
i moved this post to the Acorn Forum.
I think you have most of the connections figured out. According to the manual X3 is by default
programmed to be the fault reset. I'm attaching a draft schematic of the connections described in the manual.
- FUJI_FRENIC-Mini-DRAFT.pdf
- (155.06 KiB) Downloaded 18 times
thanks Chuck!
Thank you very much. Sorry about posting in the wrong forum.
