If you have connected your Ether1616 properly:
1: Connect the CNCPC's PHYSICAL ethernet port to the ethernet switch
2: Connect Acorn and Ether1616 to the switch using the Centroid supplied shielded Ethernet cables and power supplies.
3: Start CNC12, you should get a message that an Ether1616 was detected:
If you don't, but you can ping the IP address: 10.168.41.3
Post by eng199 » Wed Jun 01, 2022 5:43 am
IPv6 should be disabled for the on board Ethernet adapter.
This sometime causes problems with ETH1616 detection.
https://networking.grok.lsu.edu/article ... leid=17573
Here are some related posts:
https://centroidcncforum.com/viewtopic. ... it=eth1616
https://centroidcncforum.com/viewtopic.php?f=61&t=1451
Ether1616 Not Recognized
12 users liked this post
