Pendent help
Pendent help
Can i use the imac p4-s pendent on the acorn controller , if so how to wire
Re: Pendent help
No, Only Centroid Pendants will work, but there are some USB keyboard emulators that will offer some function at a lower price
- CNC Control System Serial Number: 4372
Re: Pendent help
Yes you can use a Playstation controller on acorn it is done the same way a Xbox controller is used see this video on YouTube
The name of the video is Centroid acorn cnc with an Xbox controller by Rick Sparber... check it out I did the same to use the Xbox controller until I got my mpg
Re: Pendent help
Again, generally any keyboard emulator will work.
Alternately, a nice inexpensive solution is the Contour Shuttle Express (Same thing Tormach uses):
These are supported by Centroid:
https://www.centroidcnc.com/centroid_di ... ntrol.html
Contour Shuttle Express info:
https://www.centroidcnc.com/centroid_di ... uttle.html
