Page 1 of 2
Pin terminals or tinned wires
Posted: Fri Dec 13, 2019 11:00 pm
by Livnpaintball
What did you guys use to connect to the Acorn, pin terminals on the wires or just tin them? Was also thinking of the RJ45 converters.
Re: Pin terminals or tinned wires
Posted: Sat Dec 14, 2019 1:33 am
by ShawnM
Ferrule connectors on the wires, you could buy this kit for $23 on ebay.
https://www.ebay.com/itm/Ferrule-Crimpi ... 749.l2649
Posted: Sat Dec 14, 2019 7:55 am
by Livnpaintball
Thanks!
Posted: Sun Dec 15, 2019 9:17 am
by tblough
Another +1 on ferrules. You have to be very careful on tinning. If the wires wick the solder past where the wire connection is made, you run the risk of fatigue breaking the wire. And, if this happens past where the insulation starts, you now have an intermittent connection that's almost impossible to find.
Posted: Sun Dec 15, 2019 1:29 pm
by cbb1962
tblough wrote: ↑Sun Dec 15, 2019 9:17 am
+2
Posted: Sun Dec 15, 2019 3:58 pm
by Gary Campbell
Tinned, especially fully tinned is not recommended. That said, I believe tinning is better than nothing, but no where as good as installed ferrules.
Posted: Mon Dec 16, 2019 7:12 am
by Livnpaintball
Gary Campbell wrote: ↑Sun Dec 15, 2019 3:58 pm
That is a drawer to be envy of.
Posted: Tue May 19, 2020 5:32 pm
by Livnpaintball
Guys, I’m getting back to the build, do you like terminal strips or terminal blocks? I’m leaning toward the blocks for power distribution.
Posted: Tue May 19, 2020 7:06 pm
by tblough
Terminal blocks take up less room than strips and ferrules are cheaper than ring or spade terminals.
Posted: Wed Jun 10, 2020 8:20 am
by CNCMaryland
cbb1962 wrote: ↑Sun Dec 15, 2019 1:29 pm
+2
+3 the best way to go no doubt.
