Machine Tool Coordinate Systems, Axis Conventions
Posted: Sat Oct 26, 2019 8:56 am
Just though I'd post this here as a reference for the DIY'ers when setting up their machine tool coordinate systems. All illustrations were taken from ISO 841:2001(E) Industrial automation systems and integration — Numerical control of machines — Coordinate system and motion nomenclature
Z-Axis
The Z axis is parallel to the principal spindle of the machine.
Where possible, the X axis shall be horizontal.
Positive Y shall be in the direction to make a right-hand set of coordinates
Examples
Z-Axis
- On machines used for milling, grinding, boring, drilling and tapping, the spindle rotates the tool.
- On machines such as lathes, cylindrical grinders and others which generate a surface of revolution, the spindle
rotates the work piece. - For cutting and forming machines, the Z axis shall be perpendicular to the work-holding surface.
- For coordinate measuring machines, the Z axis should be collinear with the acceleration of gravity vector (i.e.
perpendicular to the surface of the earth).
- Machines with rotating tools
- Horizontal Z axis: Positive X shall be to the right when viewed in the negative Z direction.
- Vertical Z axis, single column: Positive X shall be to the right when viewed from the front of the machine into the
column. - Vertical Z axis, gantry type: Positive X shall be to the right when viewed from the principal spindle to the left-hand
gantry support.
- Machines with rotating workpieces
- The X axis shall be radial and parallel to the cross slide. The positive direction shall be away from the axis of
rotation.
- Machines with no spindle
- For cutting machines, positive X shall be parallel to and in the principal direction of cutting.
- For coordinate measuring machines, positive X shall be defined by the manufacturer.
Examples
