Using mechanical and ZRI/Proximity switches for homing a lathe
Re: Using mechanical and ZRI/Proximity switches for homing a lathe
That code is just an example, you need to adjust it for your machine. There are also other settings in the wizard that need to be set so the software doesn’t overwrite your CNC.hom file.
I've watched this thread for a while and the new activity got me to thinking that I should finish my install. My hesitation came from not completely understanding if the ALLIN1CHRIS' code is universal - based on his name I want to know if it will work on an Acorn install.
What kind of adjustments would be required for a three axis mill? From looking at the code it appears that changing the 5000X to the proper channel would be one required change...
My Tree J325 & Projectshttps://photos.app.goo.gl/LLHf8M84eQYwP3ph6
MAKING PARTS https://www.youtube.com/shorts/MSQ4TyTzFkk
Hardinge CHNC4 Retrofithttps://photos.app.goo.gl/244YnF9ykyUf7mfq7
It is somewhat universal but changes would need to be made on a machine by machine basis since no two machines are setup the exact same. Yes, you'd need changes for the correct ZRI input, correct HomeAll input (the 5000X numbers as you pointed out), axis homing order and more importantly homing direction of each axis. All fairly simple code changes. Chris also gave a link in his post to understanding how to write your own macros and understand what the code means.
- CNC Control System Serial Number: C8FD19F6D5CF-0403180778
Everything seems to be right in the code that I edited from Chris’s example. It matches what cnc12 produces for a standard .hom file with my setup in regards to the #5000 and inputs. It still will not stop when input 1, homeall, is triggered on x. It does on z however. Directions should not matter at this point since axis are not coupled yet.
Typed all of the above and did I final test and I received several fatal errors. Reinstalled cnc12, restored repot and all is working as expected. Thank you
Can you please post a FRESH report?TCandee wrote: ↑Mon Nov 07, 2022 4:01 pm Everything seems to be right in the code that I edited from Chris’s example. It matches what cnc12 produces for a standard .hom file with my setup in regards to the #5000 and inputs. It still will not stop when input 1, homeall, is triggered on x. It does on z however. Directions should not matter at this point since axis are not coupled yet.
see attached report and .hom file
- cnct.hom
- (1.22 KiB) Downloaded 10 times
- report_3484E41C151B-0601226279_2022-11-07_12-51-20.zip
- (748.01 KiB) Downloaded 7 times
I'm trying to understand the code better - I don't know what the 9822 is...
IF !#[50000 + #9822] THEN M225 #100 "HomeAll switch tripped!!!\nPlease clear before Homing.\n\nPress Cycle Cancel to end Homing"
Do you have the macro programming manual? It will explain system variable and parameters. 9000-9999 are the system variables for parameters 0-999.
https://www.centroidcnc.com/centroid_di ... amming.pdf
Parameter 822 from the variable #9822 is the input assigned to "HomeAll" by the wizard.
Yes I have the manual - my quick search for 9822 did not find a result. Now I see how to get there. I think I know just enough to understand what's going on with the homing file and I believe it will work for me. The basic Key seems to be knowing the order of axis homing and direction. Thanks to the comments in the "generic" homing file it makes it easier to understand.
I realize this is not a ZRI issue but it is related to why I could not get it to work.
I am not unable to open the wizard. I get a fatal error message stating that the wizard cannot open when a job is running or it is in MIDI mode. neither is true. reinstalled CNC12 again and restored the report with the same result
