ShawnM wrote: ↑Wed Oct 02, 2019 6:34 pm
Hi Vincent, which macro? There are dozens of them for the tool change and z zero settings, you'll have to be a bit more specific for anyone to help answer your question.
Hi ShawnM
I Used the macro on top of this list (the 2 version) I've made a copy down here.
Sorry not being clear
Vincent
; File: mfunc6JogToToolTouchOff-tt1.mac - rename to mfunc6.mac to use
; Purpose: Tool change macro for Acorn router with TT1 in temporary location.
; Name: Scott Pratt
; Date: 27 Jan 2018
; Modified:
; Associated SRC code: Acorn-universal.src
; Require CNC12 4.10+
; Variables used:
; #100 = Reset current Z part 0 selection. 0 = skip, 1 = Reset Z0
#101 = 5 ;Length of time to display temporary M225 messages
; #102 = Fast probing rate
; #103 = Slow probing rate
; #104 = TT1 PLC input.
; #105 = Current user entered configuration value
#106 = 0 ;Length of time to wait for cycle start M225 messages
; #4006 = imperial or metric mode. 20 = imperial, 21 == metric
; Parameters:
; 11(#90011) or 44(#90044) TT1 PLC input. If only 11 is set, the value in 11 will be used.
; If 44 is set, 44 will be used regardless of the value of 11.
; 14(#90014) Fast probing rate. Rate to probe for initial contact of TT1
; 15(#90015) Slow probing rate. Rate for actual measurement and retract.
; 41(#90041) Whether the height of the tool detector stored in parameter 71 when touch is detected. 1 = Yes. 0 = No.
; 71(#90071) This is the height of the TT1 and the Z position to set when touch is detected.
IF #50001 ;Force lookahead to stop processing
IF #4201 || #4202 THEN GOTO 1000 ;Skip when graphing or searching
#100 = 0
#102 = 0
#103 = 0
#104 = 0
#105 = 0
M5 ;Turn off spindle
N100 ;Check to make sure a TT1 is correctly configured
;Check for PLC input
;If check if either parameter 11 or parameter 44 are > 0
IF !#9011 && !#9044 THEN M225 #106 "No PLC input has been configured for the Tool Touch Off device.\nPlease enter the PLC input for the Tool Touch Off device in parameter 11\nPress Cycle Cancel to end job now."
IF !#9011 && !#9044 THEN GOTO 100
;Check if current plc input set in parameter 44 is between 1 & 8 if it is less <= 50000
IF [#9044 > 8] && [#9044 <= 50000] THEN M225 #106 "The PLC input entered into parameter 44 in invalid.\nPlease enter a value of between 1 and 8 into parameter 44\nPress Cycle Cancel to end job now."
IF [#9044 > 8] && [#9044 <= 50000] THEN GOTO 100
;If parameter 44 is != 0 && < 50000, check if current plc input set in parameter 44 is between 1 & 8
IF [[#9044 != 0] && [#9044 < 50000]] && [[#9044 < 1] || [#9044 > 8]] THEN M225 #106 "The PLC input entered into parameter 44 in invalid.\nPlease enter a value of between 1 and 8 into parameter 44\nPress Cycle Cancel to end job now."
IF [[#9044 != 0] && [#9044 < 50000]] && [[#9044 < 1] || [#9044 > 8]] THEN GOTO 100
IF #50001
;If parameter 44 is != 0 && >= 50000, check if current plc input set in parameter 44 is between 50001 & 50008
IF [[#9044 != 0] && [#9044 >= 50000]] && [[#9044 < 50001] || [#9044 > 50008]] THEN M225 #106 "The PLC input entered into parameter 44 in invalid.\nPlease enter a value of between 1 and 8 into parameter 44\nPress Cycle Cancel to end job now."
IF [[#9044 != 0] && [#9044 >= 50000]] && [[#9044 < 50001] || [#9044 > 50008]] THEN GOTO 100
;If parameter 44 = 0 && parameter 11 < 50000, check if current plc input set in parameter 11 is between 1 & 8 if it is less <= 50000
IF [#9044 == 0] && [#9011 < 50000] && [[#9011 < 1] || [#9011 > 8]] THEN M225 #106 "The PLC input entered into parameter 11 in invalid.\nPlease enter a value of between 1 and 8 into parameter 11\nPress Cycle Cancel to end job now."
IF [#9044 == 0] && [#9011 < 50000] && [[#9011 < 1] || [#9011 > 8]] THEN GOTO 100
;If parameter 44 = 0 && parameter 11 >= 50000, check if current plc input set in parameter 11 is between 50001 & 50008
IF [#9044 == 0] && [#9011 >= 50000] && [[#9011 < 50001] || [#9011 > 50008]] THEN M225 #106 "The PLC input entered into parameter 11 in invalid.\nPlease enter a value of between 1 and 8 into parameter 11\nPress Cycle Cancel to end job now."
IF [#9044 == 0] && [#9011 >= 50000] && [[#9011 < 50001] || [#9011 > 50008]] THEN GOTO 100
;Check that touch off device height has been set
IF #9071 == 0 THEN M225 #106 "The height for the tool touch off device has not been set in parameter 71.\nPlease measure the height of your tool touch off device and enter it parameter 71\nPress Cycle Cancel to end job now."
IF #9071 == 0 THEN GOTO 100
IF #9044 != 0 THEN #104 = #9044 ;Set TT1 input to value in parameter 44 if it's not = to 0.
IF #9044 == 0 THEN #104 = #9011 ;Set TT1 input to value in parameter 11 if parameter 44 = 0.
IF #104 > 50000 THEN #104 = #104 - 50000
;Check/set probing rates
IF [#9014 == 0] && [#4006 == 20] THEN #102 = 10 ;If fast probing rate = 0, set to default 10"/min
IF [#9014 != 0] && [#4006 == 20] THEN #102 = #9014 ;If fast probing rate != 0, set to value in #9014
IF [#9014 == 0] && [#4006 == 21] THEN #102 = 254 ;If fast probing rate = 0, set to default 254mm/min
IF [#9014 != 0] && [#4006 == 21] THEN #102 = #9014 ;If fast probing rate != 0, set to value in #9014
IF [#9015 == 0] && [#4006 == 20] THEN #103 = 1 ;If slow probing rate = 0, set to default 1"/min
IF #50001
IF [#9015 != 0] && [#4006 == 20] THEN #103 = 1 ;If slow probing rate != 0, set to value in #9015
IF #50001
IF [#9015 == 0] && [#4006 == 21] THEN #103 = 25.4 ;If slow probing rate = 0, set to default 25.4 mm/min
IF [#9015 != 0] && [#4006 == 21] THEN #103 = 25.4 ;If slow probing rate != 0, set to value in #9015
N150
G28
M225 #106 "#)Please change tool to tool #%.0f\nPress Cycle Start to continue" #4120
N200 ;Prompt user for resetting Z0 position
M224 #100 "#)Would you like to reset the current Z0 position?\n#)Press 0 to continue without resetting Z0\n#)Press 1 to auto reset current Z0\n#)Press Cycle Start to continue"
IF #100 == 0 THEN GOTO 400 ;Skip if user chose not to reset Z0
IF #100 > 1 THEN GOTO 200 ;Go back to prompt user if invalid value was selected
N250 ;Prompt to put clamp om
M200 "#)Put Clip on cutter\nJog the cutter over top of the Tool Touch Off\nPress Cycle Start to continue"
N300 ;Probe TT1
M115 /Z P[#104] F[#102] ;Move at fast probing rate until TT1 detected
G91 Z#9013 F[#102] ;Move up the distance set in P13.
M115 /Z P[#104]F[#103] ;Move at slow probing rate until TT1 detected
G90
G92 Z[#9071] ;Set Z position to 0 + detector height stored in parameter 71 - material thickness
G4 P1 ;Wait 1 second
G53 Z0 ;Retract Z
M225 #106 "#)Remove Clip from cutter, turn spindle On if needed\nPress Cycle Start to continue"
N400
N1000 ;End of macro
