Output Control Both Auto and Manual < Acorn tech support review >
Posted: Sun Jan 07, 2018 11:29 pm
Ok, so in over my head again.
I have my preheat and cut solenoids working very well in place of the flood and mist. (see previous thread viewtopic.php?f=60&t=1354)
The m code works great in auto mode and the keyboard works great in manual. But now I want to be complicated and develop a hybrid mode. I would like to be able to manually operate them at the start of the cut and have the m code shut them off at the end. I tried creating new macros and mapping the function keys to the outputs hopping that I would avoid the inherent limitations of the coolant keys. I successfully mapped the keys to the outputs, but there were two problems. One is that I prefer the toggling of the coolant buttons one button both on and off. When I used an AUX key I needed to use separate keys for on and off. The other problem is that the AUX keys did not function while the program was active. I assume that both of these problems are because I have no idea what I am doing.
So what I am asking is it more feasible to allow simultaneous manual and auto control of the coolant function or to enable manual control of an AUX key during the running cycle?
I tried playing around in the PLC code a bit, hoping to remove the restrictions between auto and manual but it's over my head. This is the area I was experimenting in.
No success just a bunch of compiling errors.
;--Coolant Functions
;--Toggle auto coolant mode
IF CoolAutoManKey || KbTogCoolAutoMan_M || SkinCoolAutoMan_M THEN (CoolantAutoManualPD)
IF (!CoolAutoModeLED && CoolantAutoManualPD) || OnAtPowerUp_M
THEN SET CoolAutoModeLED
IF (CoolAutoModeLED && CoolantAutoManualPD)
THEN RST CoolAutoModeLED
;--Report coolant mode to CNC12
IF CoolAutoModeLED THEN (SelectCoolAutoMan)
;--Display coolant mode message
;changing to auto coolant mode ;2050 Auto Coolant Selected 2 + 50*256
IF (!CoolAutoModeLED && CoolantAutoManualPD && AllowKbInput_M)
THEN InfoMsg_W = AUTO_COOL_MSG
;changing to manual coolant mode ;2051 Manual Coolant Selected 2 + 51*256
IF (CoolAutoModeLED && CoolantAutoManualPD && AllowKbInput_M)
THEN InfoMsg_W = MAN_COOL_MSG
;--Flood coolant on/off
; Toggle on/off or off/on if:
; In manual mode and a toggle key was pressed
; Turn on if:
; In auto mode and have M8
; Turn off if:
; Any fault or error
; In auto mode and don't have M8
; Doing tool check (?)
IF CoolFloodKey || KbFloodOnOff_M || SkinCoolFlood_M THEN (CoolantFloodPD)
IF ((Flood ^ (!CoolAutoModeLED && CoolantFloodPD))
|| CoolAutoModeLED && M8)
&& !(SV_STOP ||
CoolAutoModeLED && !M8 ||
ErrorFlag_M ||
DoToolCheck)
THEN (Flood), (CoolFloodLED), (SelectCoolantFlood)
;--Mist coolant on/off
IF (CoolMistKey || KbMistOnOff_M || SkinCoolMist_M) THEN (CoolantMistPD)
IF ((Mist ^ (!CoolAutoModeLED && CoolantMistPD))
|| CoolAutoModeLED && M7)
&& !(SV_STOP ||
CoolAutoModeLED && !M7 ||
ErrorFlag_M ||
DoToolCheck)
THEN (Mist), (CoolMistLED), (SelectCoolantMist)
