Various CNC router machines, CO2 laser cutting machines, fiber laser cutting machines, laser marking machines for sale.
Wish you a prosperous business.
CNC router machines for sale
Re: CNC router machines for sale
put an Acorn controller on them an you'd sell more:-))
this forum is for Acorn CNC controllers.
See https://www.centroidcnc.com/centroid_di ... oller.html
much better than RICHAUTO, WEIHONG, NC-STUDIO, MACH3, SYNTEC, LNC
Great. Thank you for your sharing. We will make a servy.cnckeith wrote: ↑Fri Aug 12, 2022 11:25 am this forum is for Acorn CNC controllers.
I have a question, in which regions will people use this system frequently? If possible, we would like to promote it.
hello.
all over the world!
all over the world!
Acorn CNC is #1 !!!!!
No need to make a survey.beswellcnc wrote: ↑Sun Aug 14, 2022 7:18 amGreat. Thank you for your sharing. We will make a servy.cnckeith wrote: ↑Fri Aug 12, 2022 11:25 am this forum is for Acorn CNC controllers.
Centroid Acorn is a step and direction motion controller, using ethernet communication between the PC and the motion controller.
Motion controller has a TRUE encoder input for the spindle offering outstanding single point threading, rigid tapping etc.
The Acorn motion controller also handles all motion control. Windows 10 is the user interface.
Centroid CNC 12 is the software. So, both the software and the hardware come from the same manufacturer.
See all the Centroid CNC Acorn specs here: https://www.centroidcnc.com/centroid_di ... oller.html
Further, Centroid core business has ALWAYS supported CNC Machine motion control for well over 30 years.
Software can support Mill, Lathe, Router, Laser and now Plasma. You would be hard pressed to find another manufacturer that can do that with the same hardware and software.
You are using Mach 3, outdated and no longer supported. You really should give Centroid Acorn a try.
Sorry, it is not cheap junk, but it is well supported commercial grade CNC Motion controller.
