Hello Centroiders,
I currently have a CNC router with Clearpath motors and the CNC Controller kit.
Looking to get another CNC to my shop like a 6090 frame or similar. I need at least 48" by 18". It will have a similar setup with Clearpath motors and the CNC controller kit.
Do you guys have anything for sale or can you post some links to any frame kits that will do the job along with what I mentioned above?
Tony Maninha
Looking for CNC frame
- CNC Control System Serial Number: 0035FF98CA2D-0813215079
Re: Looking for CNC frame
Good luck in your search Tony and keep in mind a 6090 frame isn't 48", not even close. Is this frame for custom cues or something else? If it's for light duty have you thought about building a frame with the extruded aluminum? They are good for light duty work and be be an option for you.
Shawn,ShawnM wrote: ↑Wed Apr 06, 2022 2:14 pm Good luck in your search Tony and keep in mind a 6090 frame isn't 48", not even close. Is this frame for custom cues or something else? If it's for light duty have you thought about building a frame with the extruded aluminum? They are good for light duty work and be be an option for you.
Just looking for something where I can have at least 36" between centers and a few stations for turning and engraving.
A 6090 type frame would work or 2'x4'...
I am looking for something I can put together fairly easily, like a kit and it is for pool cue building. I do not have great machine shops around. I am going to try to put the electronics together myself because it is the only way to learn...
You may want to check with AVID. I have a customer that runs my controllers and he orders 2' by 6 or 8' machines from them for snowboard machining.
Hey Tony, I've got a gerber 404 (cutting area oround 50x52 inches) for sale. ($2500) I got it to retrofit and then found a 4x8 table(gerber as well) and swapped that one to acorn controller and clearpath servos. I can get pics of everything if your interested
Hello Heath,Heath_R wrote: ↑Tue May 30, 2023 8:15 pm Hey Tony, I've got a gerber 404 (cutting area oround 50x52 inches) for sale. ($2500) I got it to retrofit and then found a 4x8 table(gerber as well) and swapped that one to acorn controller and clearpath servos. I can get pics of everything if your interested
Sent you a pm. Feel free to send me some pictures.
https://www.facebook.com/marketplace/it ... tid=dXMIcH
Here's s link to the sale add on market place
