ShopBot RBK ReDux (or BYOB)
Posted: Sat Feb 26, 2022 2:11 pm
I have for sale a recently upgraded SB RBK control box. It reuses the Torroid DC power supply, Oriental drives and door switch. All other components are new. Control board is a Centroid Acorn 4. Comes complete with Lenovo M93 (Win10Pro, 8gb RAM, SSD), Centroid Pro Router License and setup to your system. Here is a list of the upgrades over the decade old OEM specs:
Full backplane vs partial on the OEM
Cooling fans added
Replaced "daisy chain" grounds with single point
Single power source (240AC #Amps for spindle, 110vac for router)
Added shielded stepper data cables, increased step resolution
Upgraded 24vdc power supply
Upgraded VFD contactor
VFD speed & logic harness
Fuses replaced with circuit breakers
8 inputs, 8 outputs with relays (7 with laser)
Spindle speed and logic control
JTech (type) PWM laser support
Independent dual axis autosquare support
Added "User Connection Terminals" for simplified accessory wiring
3 layer "sensor" terminals for prox homing sensors & Z (tool) setter
Translated SB user friendly macros
Centroid Wireless MPG support
NOTES: Some features listed above are extra cost. System has been tested at ~3666 steps/inch @ 1000 ipm (no load) YMMV depending on age & condition of your machine.
We no longer accept trades or exchange. As an alternative, you can send in your RBK box and have it upgraded for $1800 plus shipping. Usual turnaround on BYOB is 2-3 weeks.
Email: gcnc411@gmail.com for more information
Cooling fans added
