Hi all, my 4th axis unit developed a leak which resulted in the encoder failing. I'm keen to replace the encoder if possible. The original servo is an Electrocraft E643 DC servo (by Reliance Motion Control) and the encoder is a Renco PN: 77678-157. Any help or leads would be much appreciated.
Wanted: Renco Encoder (or Electrocraft E643 DC servo w/ encoder) to suit Yuasa 4th Axis
Re: Wanted: Renco Encoder (or Electrocraft E643 DC servo w/ encoder) to suit Yuasa 4th Axis
hello. what cnc control are you using with this motor?
- CNC Control System Serial Number: 0611071030
Hi Keith,
M400S with Quad drive 4-4-3-4.
