Many of you know I retrofit imported machines and upfit them for specialty use. That means I am left with a good number of unused electronic parts that I have no use for. If you are looking to get into a self build, these parts may save you some bucks. All of these parts have actually been tested for a few minutes before removal. Unpictured I have a number of switches, fuses, contactors, etc. Prefer to sell quantities around 50% of current pricing and give another 20% on 4 or more (or 5 for the price of 4)
I can customize any or all of these, bore pulleys, machine ballscrews, program drives, supply wiring harnesses , whatever is needed at extra cost, of course.
I accept credit cards or PayPal. I will box and weigh and add shipping costs added at the time of shipping.
Here is a list:
~630 ozin NEMA34 motors (14mm shaft) $40 Buy more than 5, $30 each
DMA860H Stepper Drives (7.2A, AC/DC) Buy a motor & drive, I'll throw in motor wires
Inductive (3 wire) Limit/Home Sensor 3 for $10
Motor Wires 18ga, 15 to 20 ft long $5 each
70 volt AC 1200w power supply $50 each
2.2kw water cooled spindle, wire and VFD 230v single phase input Preprogrammed $250
Contact Gary at GCnC411@gmail.com for more info or to purchase
Takeoff Motors, Drives, Power Supplies, etc For Sale
Re: Takeoff Motors, Drives, Power Supplies, etc For Sale
All that remains are 2 power supplies and 6 motors
I am refreshing this thread as I have "the goodies" from at least 3 more machines. 4, 6 & 8A drives. ~600 & 900ozin motors. AC & DC power supplies. 3hp (18k) & 5hp (24k) WC spindles with matching VFDs'. Spindle wires, motor wires. Breakers, fuses terminal blocks... list goes on and on.
I also have a closed circuit (radiator, pump, reservoir, digital flow & temp display with fittings and tubing) cooling kit for the watercooled spindles.
Prices are right, first come, first served. email GCnC411@gmail.com
- CNC Control System Serial Number: Acorn333
My name is Paul I'm from Florida I got a Mill port
10 by 50 knee Mill I'd like to convert it into CNC I have a acorn bored never run nothing c&c this is my first time trying to do most of it myself I'm just looking around for parts and bracket kits and stuff for the motors
Paul...
Most of this lot are off routers, other than the motors and a few other components, not much would be applicable to a mill.
- CNC Control System Serial Number: C143226
Do you still have any proximity switches? I'm looking for npn normally closed. I need 8 each
martin
martin
It may have gotten lost, but I still have one each 2.2kw (3hp) and 3.7kw (5hp) water cooled spindles remaining cheap. VFD's available.
Note: These are not "new in box", but they are unused takeoffs from upgraded machines
Spindles have all been sold
