C Axis Lathe Situation
scatgo
Post by scatgo »
In do have some experience with X Y Z programing on a milling machine but i know nothing about C axis programming. Centroid has a video of the type of work i need to do and a sample program. I was hoping someone could help me decipher the sample program so I can learn how to deal with this. I would guess that all the programming would start at zero degrees. And C- would rotate the spindle clockwise and C+ would rotate the spindle counterclockwise. But if you look at the program all C axis move are C-????
https://www.centroidcnc.com/cnc_c_axis_lathe.html#:
G20 ; INCH
G28 ; TOOL CHANGE POSITION
G97 G98 ; Cancel Constant Surface Speed and Feed per Minute
; This set up was the a gang style lathe.
; Tool 1 is a 1/4" end mill in a Live tool holder.
; Live tooling has the 1/4" end held horizontal to the X axis plane.
T0101 ; CHANGE TO TOOL 1 WITH OFFSET 1 for 1/4" ENDMILL
M51 ; TURN C AXIS ON
M23 ;Turn Live tooling ON
G0 G54 X1.5 M8
G0 Z-2.0035
C-75.068
G0 X1.25
G98 G1 X.95 Z-1.8975 C-87.222 F1396.21
Z-1.1904 C-168.251 F2000.
Z-1.1769 C-170.046
Z-1.1657 C-172.04
Z-1.1571 C-174.196
Z-1.1513 C-176.47
Z-1.1483 C-178.815
C-181.185
Z-1.1513 C-183.531
Z-1.1571 C-185.805
Z-1.1657 C-187.961
Z-1.1769 C-189.955
Z-1.1904 C-191.746
Z-1.8975 C-272.778
Z-1.9131 C-274.326 F1911.47
Z-1.9305 C-275.607 F1571.38
Z-1.9493 C-276.592 F1200.22
Z-1.9692 C-277.259 F810.25
Z-1.9897 C-277.597 F408.11
Z-2.0103 F25.
Z-2.0308 C-277.259 F408.1
Z-2.0507 C-276.592 F810.25
Z-2.0695 C-275.607 F1200.21
Z-2.0869 C-274.326 F1571.37
Z-2.1025 C-272.774 F1916.53
Z-2.8096 C-191.749 F2000.
Z-2.8231 C-189.955
Z-2.8343 C-187.961
Z-2.8429 C-185.805
Z-2.8487 C-183.531
Z-2.8517 C-181.185
C-178.815
Z-2.8487 C-176.47
Z-2.8429 C-174.196
Z-2.8343 C-172.04
Z-2.8231 C-170.046
Z-2.8096 C-168.255
Z-2.1025 C-87.222
Z-2.0869 C-85.675 F1910.84
Z-2.0695 C-84.394 F1571.38
Z-2.0507 C-83.409 F1200.22
Z-2.0308 C-82.742 F810.25
Z-2.0103 C-82.404 F408.11
Z-1.9897 F25.
Z-1.9692 C-82.742 F408.11
Z-1.9493 C-83.409 F810.25
Z-1.9305 C-84.394 F1200.21
Z-1.9131 C-85.675 F1571.37
Z-1.8975 C-87.227 F1916.53
Z-2.0035 C-75.068 F2000.
X1.2 F7.
X.9 Z-1.8975 C-87.222 F1414.39
Z-1.1769 C-170.046
Z-1.1657 C-172.04
Z-1.1571 C-174.196
Z-1.1513 C-176.47
Z-1.1483 C-178.815
C-181.185
Z-1.1513 C-183.531
Z-1.1571 C-185.805
Z-1.1657 C-187.961
Z-1.1769 C-189.955
Z-1.1904 C-191.746
Z-1.8975 C-272.778
Z-1.9131 C-274.326 F1952.08
Z-1.9305 C-275.607 F1593.71
Z-1.9493 C-276.592 F1210.08
Z-1.9692 C-277.259 F813.26
Z-1.9897 C-277.597 F408.49
Z-2.0103 F25.
Z-2.0308 C-277.259 F408.49
Z-2.0507 C-276.592 F813.26
Z-2.0695 C-275.607 F1210.08
Z-2.0869 C-274.326 F1593.7
Z-2.1025 C-272.774 F1957.48
Z-2.8231 C-189.955
Z-2.8343 C-187.961
Z-2.8429 C-185.805
Z-2.8487 C-183.531
Z-2.8517 C-181.185
C-178.815
Z-2.8487 C-176.47
Z-2.8429 C-174.196
Z-2.8343 C-172.04
Z-2.8231 C-170.046
Z-2.8096 C-168.255
Z-2.1025 C-87.222
Z-2.0869 C-85.675 F1951.42
Z-2.0695 C-84.394 F1593.71
Z-2.0507 C-83.409 F1210.08
Z-2.0308 C-82.742 F813.26
Z-2.0103 C-82.404 F408.49
Z-1.9897 F25.
Z-1.9692 C-82.742 F408.49
Z-1.9493 C-83.409 F813.26
Z-1.9305 C-84.394 F1210.08
Z-1.9131 C-85.675 F1593.7
Z-1.8975 C-87.227 F1957.48
X1.15 F7.
X.85 Z-1.8975 C-87.222 F1432.39
Z-1.1769 C-170.046
Z-1.1657 C-172.04
Z-1.1571 C-174.196
Z-1.1513 C-176.47
Z-1.1483 C-178.815
C-181.185
Z-1.1513 C-183.531
Z-1.1571 C-185.805
Z-1.1657 C-187.961
Z-1.1769 C-189.955
Z-1.1904 C-191.746
Z-1.8975 C-272.778
Z-1.9131 C-274.326 F1992.99
Z-1.9305 C-275.607 F1615.74
Z-1.9493 C-276.592 F1219.64
Z-1.9692 C-277.259 F816.14
Z-1.9897 C-277.597 F408.85
Z-2.0103 F25.
Z-2.0308 C-277.259 F408.85
Z-2.0507 C-276.592 F816.14
Z-2.0695 C-275.607 F1219.64
Z-2.0869 C-274.326 F1615.73
Z-2.1025 C-272.774 F1998.73
Z-2.8231 C-189.955
Z-2.8343 C-187.961
Z-2.8429 C-185.805
Z-2.8487 C-183.531
Z-2.8517 C-181.185
C-178.815
Z-2.8487 C-176.47
Z-2.8429 C-174.196
Z-2.8343 C-172.04
Z-2.8231 C-170.046
Z-2.8096 C-168.255
Z-2.1025 C-87.222
Z-2.0869 C-85.675 F1992.28
Z-2.0695 C-84.394 F1615.74
Z-2.0507 C-83.409 F1219.64
Z-2.0308 C-82.742 F816.14
Z-2.0103 C-82.404 F408.85
Z-1.9897 F25.
Z-1.9692 C-82.742 F408.85
Z-1.9493 C-83.409 F816.14
Z-1.9305 C-84.394 F1219.64
Z-1.9131 C-85.675 F1615.73
Z-1.8975 C-87.227 F1998.73
X1.1 F7.
X.8 Z-1.8975 C-87.222 F1450.18
Z-1.1769 C-170.046
Z-1.1657 C-172.04
Z-1.1571 C-174.196
Z-1.1513 C-176.47
Z-1.1483 C-178.815
C-181.185
Z-1.1513 C-183.531
Z-1.1571 C-185.805
Z-1.1657 C-187.961
Z-1.1769 C-189.955
Z-1.1904 C-191.746
Z-1.8975 C-272.778
Z-1.9131 C-274.326
Z-1.9305 C-275.607 F1637.36
Z-1.9493 C-276.592 F1228.86
Z-1.9692 C-277.259 F818.89
Z-1.9897 C-277.597 F409.2
Z-2.0103 F25.
Z-2.0308 C-277.259 F409.2
Z-2.0507 C-276.592 F818.89
Z-2.0695 C-275.607 F1228.86
Z-2.0869 C-274.326 F1637.36
Z-2.1025 C-272.774 F2000.
Z-2.8096 C-191.749
Z-2.8231 C-189.955
Z-2.8343 C-187.961
Z-2.8429 C-185.805
Z-2.8487 C-183.531
Z-2.8517 C-181.185
C-178.815
Z-2.8487 C-176.47
Z-2.8429 C-174.196
Z-2.8343 C-172.04
Z-2.8231 C-170.046
Z-2.8096 C-168.255
Z-2.1025 C-87.222
Z-2.0869 C-85.675
Z-2.0695 C-84.394 F1637.36
Z-2.0507 C-83.409 F1228.86
Z-2.0308 C-82.742 F818.89
Z-2.0103 C-82.404 F409.2
Z-1.9897 F25.
Z-1.9692 C-82.742 F409.2
Z-1.9493 C-83.409 F818.89
Z-1.9305 C-84.394 F1228.86
Z-1.9131 C-85.675 F1637.36
Z-1.8975 C-87.227 F2000.
G0 X1.5 C-87.222
Z-2.3605 C-179.979
X1.2
G1 X.95 F7.
Z-2.0238 C-218.653 F2000.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.9 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.85 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.8 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
G0 X1.5
Z-2.163 C-179.948
X1.2
G1 X.95 F7.
Z-1.999 C-198.78 F2000.
Z-1.8366 C-180.069
Z-2.0009 C-161.227
Z-2.163 C-179.948
X.9 F7.
Z-1.8366 C-180.069
Z-2.0009 C-161.227
Z-2.163 C-179.948
X.85 F7.
Z-1.8366 C-180.069
Z-2.0009 C-161.227
Z-2.163 C-179.948
X.8 F7.
Z-1.8366 C-180.069
Z-2.0009 C-161.227
Z-2.163 C-179.948
G0 X1.5
Z-2.0177 C-76.689
X1.25
G1 X.95 Z-1.9116 C-88.843 F1396.21
Z-1.2045 C-169.871 F2000.
Z-1.1918 C-171.58
Z-1.1815 C-173.497
Z-1.174 C-175.573
Z-1.1694 C-177.759
Z-1.1679 C-180.
Z-1.1694 C-182.241
Z-1.174 C-184.427
Z-1.1815 C-186.504
Z-1.1918 C-188.421
Z-1.2045 C-190.13
Z-1.9116 C-271.157
Z-1.9265 C-272.618 F1901.68
Z-1.9432 C-273.793 F1517.18
Z-1.9614 C-274.653 F1104.22
Z-1.9804 C-275.178 F670.56
Z-2. C-275.354 F224.84
Z-2.0196 C-275.178
Z-2.0386 C-274.653 F670.56
Z-2.0568 C-273.793 F1104.22
Z-2.0735 C-272.618 F1517.18
Z-2.0884 C-271.158 F1900.01
Z-2.7955 C-190.129 F2000.
Z-2.8082 C-188.421
Z-2.8185 C-186.504
Z-2.826 C-184.427
Z-2.8306 C-182.241
Z-2.8321 C-180.
Z-2.8306 C-177.759
Z-2.826 C-175.573
Z-2.8185 C-173.497
Z-2.8082 C-171.58
Z-2.7955 C-169.871
Z-2.0884 C-88.843
Z-2.0735 C-87.383 F1901.02
Z-2.0568 C-86.208 F1517.18
Z-2.0386 C-85.348 F1104.22
Z-2.0196 C-84.823 F670.56
Z-2. C-84.647 F224.84
Z-1.9804 C-84.823
Z-1.9614 C-85.348 F670.56
Z-1.9432 C-86.208 F1104.22
Z-1.9265 C-87.383 F1517.18
Z-1.9116 C-88.843 F1900.01
Z-2.0177 C-76.689 F2000.
X1.2 F7.
X.9 Z-1.9116 C-88.843 F1414.39
Z-1.1918 C-171.58
Z-1.1815 C-173.497
Z-1.174 C-175.573
Z-1.1694 C-177.759
Z-1.1679 C-180.
Z-1.1694 C-182.241
Z-1.174 C-184.427
Z-1.1815 C-186.504
Z-1.1918 C-188.421
Z-1.2045 C-190.13
Z-1.9116 C-271.157
Z-1.9265 C-272.618 F1941.66
Z-1.9432 C-273.793 F1537.25
Z-1.9614 C-274.653 F1111.89
Z-1.9804 C-275.178 F672.26
Z-2. C-275.354 F224.9
Z-2.0196 C-275.178
Z-2.0386 C-274.653 F672.26
Z-2.0568 C-273.793 F1111.88
Z-2.0735 C-272.618 F1537.25
Z-2.0884 C-271.158 F1939.88
Z-2.8082 C-188.421
Z-2.8185 C-186.504
Z-2.826 C-184.427
Z-2.8306 C-182.241
Z-2.8321 C-180.
Z-2.8306 C-177.759
Z-2.826 C-175.573
Z-2.8185 C-173.497
Z-2.8082 C-171.58
Z-2.7955 C-169.871
Z-2.0884 C-88.843
Z-2.0735 C-87.383 F1940.96
Z-2.0568 C-86.208 F1537.25
Z-2.0386 C-85.348 F1111.89
Z-2.0196 C-84.823 F672.26
Z-2. C-84.647 F224.9
Z-1.9804 C-84.823
Z-1.9614 C-85.348 F672.26
Z-1.9432 C-86.208 F1111.88
Z-1.9265 C-87.383 F1537.25
Z-1.9116 C-88.843 F1939.88
X1.15 F7.
X.85 Z-1.9116 C-88.843 F1432.39
Z-1.1918 C-171.58
Z-1.1815 C-173.497
Z-1.174 C-175.573
Z-1.1694 C-177.759
Z-1.1679 C-180.
Z-1.1694 C-182.241
Z-1.174 C-184.427
Z-1.1815 C-186.504
Z-1.1918 C-188.421
Z-1.2045 C-190.13
Z-1.9116 C-271.157
Z-1.9265 C-272.618 F1981.9
Z-1.9432 C-273.793 F1556.99
Z-1.9614 C-274.653 F1119.29
Z-1.9804 C-275.178 F673.89
Z-2. C-275.354 F224.96
Z-2.0196 C-275.178
Z-2.0386 C-274.653 F673.89
Z-2.0568 C-273.793 F1119.29
Z-2.0735 C-272.618 F1556.99
Z-2.0884 C-271.158 F1980.01
Z-2.8082 C-188.421
Z-2.8185 C-186.504
Z-2.826 C-184.427
Z-2.8306 C-182.241
Z-2.8321 C-180.
Z-2.8306 C-177.759
Z-2.826 C-175.573
Z-2.8185 C-173.497
Z-2.8082 C-171.58
Z-2.7955 C-169.871
Z-2.0884 C-88.843
Z-2.0735 C-87.383 F1981.15
Z-2.0568 C-86.208 F1556.99
Z-2.0386 C-85.348 F1119.29
Z-2.0196 C-84.823 F673.89
Z-2. C-84.647 F224.96
Z-1.9804 C-84.823
Z-1.9614 C-85.348 F673.89
Z-1.9432 C-86.208 F1119.29
Z-1.9265 C-87.383 F1556.99
Z-1.9116 C-88.843 F1980.01
X1.1 F7.
X.8 Z-1.9116 C-88.843 F1450.18
Z-1.1918 C-171.58
Z-1.1815 C-173.497
Z-1.174 C-175.573
Z-1.1694 C-177.759
Z-1.1679 C-180.
Z-1.1694 C-182.241
Z-1.174 C-184.427
Z-1.1815 C-186.504
Z-1.1918 C-188.421
Z-1.2045 C-190.13
Z-1.9116 C-271.157
Z-1.9265 C-272.618
Z-1.9432 C-273.793 F1576.32
Z-1.9614 C-274.653 F1126.4
Z-1.9804 C-275.178 F675.43
Z-2. C-275.354 F225.02
Z-2.0196 C-275.178
Z-2.0386 C-274.653 F675.43
Z-2.0568 C-273.793 F1126.4
Z-2.0735 C-272.618 F1576.31
Z-2.0884 C-271.158 F2000.
Z-2.7955 C-190.129
Z-2.8082 C-188.421
Z-2.8185 C-186.504
Z-2.826 C-184.427
Z-2.8306 C-182.241
Z-2.8321 C-180.
Z-2.8306 C-177.759
Z-2.826 C-175.573
Z-2.8185 C-173.497
Z-2.8082 C-171.58
Z-2.7955 C-169.871
Z-2.0884 C-88.843
Z-2.0735 C-87.383
Z-2.0568 C-86.208 F1576.32
Z-2.0386 C-85.348 F1126.4
Z-2.0196 C-84.823 F675.43
Z-2. C-84.647 F225.02
Z-1.9804 C-84.823
Z-1.9614 C-85.348 F675.43
Z-1.9432 C-86.208 F1126.4
Z-1.9265 C-87.383 F1576.31
Z-1.9116 C-88.843 F2000.
G0 X1.5
Z-1.8586 C-82.766
X1.2
G1 X.95 F7.
Z-1.1515 C-163.794 F2000.
Z-1.1343 C-166.051
Z-1.1197 C-168.543
Z-1.1082 C-171.231
Z-1.0997 C-174.07
Z-1.0946 C-177.009
Z-1.0929 C-180.
Z-1.0946 C-182.991
Z-1.0997 C-185.931
Z-1.1082 C-188.77
Z-1.1197 C-191.458
Z-1.1343 C-193.95
Z-1.1515 C-196.204
Z-1.8586 C-277.234
Z-1.8783 C-279.208 F1927.38
Z-1.9 C-280.873 F1616.09
Z-1.9235 C-282.199 F1279.32
Z-1.9482 C-283.162 F925.53
Z-1.9739 C-283.747 F559.93
Z-2. C-283.943 F187.41
Z-2.0261 C-283.747
Z-2.0518 C-283.162 F559.93
Z-2.0765 C-282.199 F925.53
Z-2.1 C-280.873 F1279.32
Z-2.1217 C-279.208 F1616.09
Z-2.1414 C-277.231 F1930.24
Z-2.8485 C-196.206 F2000.
Z-2.8657 C-193.95
Z-2.8803 C-191.458
Z-2.8918 C-188.77
Z-2.9003 C-185.931
Z-2.9054 C-182.991
Z-2.9071 C-180.
Z-2.9054 C-177.009
Z-2.9003 C-174.07
Z-2.8918 C-171.231
Z-2.8803 C-168.543
Z-2.8657 C-166.051
Z-2.8485 C-163.797
Z-2.1414 C-82.766
Z-2.1217 C-80.793 F1926.89
Z-2.1 C-79.128 F1616.09
Z-2.0765 C-77.802 F1279.32
Z-2.0518 C-76.839 F925.53
Z-2.0261 C-76.254 F559.93
Z-2. C-76.058 F187.41
Z-1.9739 C-76.254
Z-1.9482 C-76.839 F559.93
Z-1.9235 C-77.802 F925.53
Z-1.9 C-79.128 F1279.32
Z-1.8783 C-80.793 F1616.09
Z-1.8586 C-82.769 F1930.24
X.9 C-82.766 F1.02
Z-1.1343 C-166.051
Z-1.1197 C-168.543
Z-1.1082 C-171.231
Z-1.0997 C-174.07
Z-1.0946 C-177.009
Z-1.0929 C-180.
Z-1.0946 C-182.991
Z-1.0997 C-185.931
Z-1.1082 C-188.77
Z-1.1197 C-191.458
Z-1.1343 C-193.95
Z-1.1515 C-196.204
Z-1.8586 C-277.234
Z-1.8783 C-279.208 F1969.04
Z-1.9 C-280.873 F1640.42
Z-1.9235 C-282.199 F1291.29
Z-1.9482 C-283.162 F930.03
Z-1.9739 C-283.747 F560.92
Z-2. C-283.943 F187.44
Z-2.0261 C-283.747
Z-2.0518 C-283.162 F560.92
Z-2.0765 C-282.199 F930.03
Z-2.1 C-280.873 F1291.29
Z-2.1217 C-279.208 F1640.42
Z-2.1414 C-277.231 F1972.09
Z-2.8657 C-193.95
Z-2.8803 C-191.458
Z-2.8918 C-188.77
Z-2.9003 C-185.931
Z-2.9054 C-182.991
Z-2.9071 C-180.
Z-2.9054 C-177.009
Z-2.9003 C-174.07
Z-2.8918 C-171.231
Z-2.8803 C-168.543
Z-2.8657 C-166.051
Z-2.8485 C-163.797
Z-2.1414 C-82.766
Z-2.1217 C-80.793 F1968.52
Z-2.1 C-79.128 F1640.42
Z-2.0765 C-77.802 F1291.29
Z-2.0518 C-76.839 F930.03
Z-2.0261 C-76.254 F560.92
Z-2. C-76.058 F187.44
Z-1.9739 C-76.254
Z-1.9482 C-76.839 F560.92
Z-1.9235 C-77.802 F930.03
Z-1.9 C-79.128 F1291.29
Z-1.8783 C-80.793 F1640.42
Z-1.8586 C-82.769 F1972.09
X.85 C-82.766 F1.02
Z-1.1343 C-166.051
Z-1.1197 C-168.543
Z-1.1082 C-171.231
Z-1.0997 C-174.07
Z-1.0946 C-177.009
Z-1.0929 C-180.
Z-1.0946 C-182.991
Z-1.0997 C-185.931
Z-1.1082 C-188.77
Z-1.1197 C-191.458
Z-1.1343 C-193.95
Z-1.1515 C-196.204
Z-1.8586 C-277.234
Z-1.8783 C-279.208
Z-1.9 C-280.873 F1664.47
Z-1.9235 C-282.199 F1302.92
Z-1.9482 C-283.162 F934.35
Z-1.9739 C-283.747 F561.87
Z-2. C-283.943 F187.48
Z-2.0261 C-283.747
Z-2.0518 C-283.162 F561.87
Z-2.0765 C-282.199 F934.35
Z-2.1 C-280.873 F1302.92
Z-2.1217 C-279.208 F1664.47
Z-2.1414 C-277.231 F2000.
Z-2.8485 C-196.206
Z-2.8657 C-193.95
Z-2.8803 C-191.458
Z-2.8918 C-188.77
Z-2.9003 C-185.931
Z-2.9054 C-182.991
Z-2.9071 C-180.
Z-2.9054 C-177.009
Z-2.9003 C-174.07
Z-2.8918 C-171.231
Z-2.8803 C-168.543
Z-2.8657 C-166.051
Z-2.8485 C-163.797
Z-2.1414 C-82.766
Z-2.1217 C-80.793
Z-2.1 C-79.128 F1664.47
Z-2.0765 C-77.802 F1302.92
Z-2.0518 C-76.839 F934.35
Z-2.0261 C-76.254 F561.87
Z-2. C-76.058 F187.48
Z-1.9739 C-76.254
Z-1.9482 C-76.839 F561.87
Z-1.9235 C-77.802 F934.35
Z-1.9 C-79.128 F1302.92
Z-1.8783 C-80.793 F1664.47
Z-1.8586 C-82.769 F2000.
X.8 C-82.766 F1.02
Z-1.1343 C-166.051
Z-1.1197 C-168.543
Z-1.1082 C-171.231
Z-1.0997 C-174.07
Z-1.0946 C-177.009
Z-1.0929 C-180.
Z-1.0946 C-182.991
Z-1.0997 C-185.931
Z-1.1082 C-188.77
Z-1.1197 C-191.458
Z-1.1343 C-193.95
Z-1.1515 C-196.204
Z-1.8586 C-277.234
Z-1.8783 C-279.208
Z-1.9 C-280.873 F1688.14
Z-1.9235 C-282.199 F1314.18
Z-1.9482 C-283.162 F938.48
Z-1.9739 C-283.747 F562.76
Z-2. C-283.943 F187.51
Z-2.0261 C-283.747
Z-2.0518 C-283.162 F562.76
Z-2.0765 C-282.199 F938.48
Z-2.1 C-280.873 F1314.18
Z-2.1217 C-279.208 F1688.14
Z-2.8485 C-196.206
Z-2.8657 C-193.95
Z-2.8803 C-191.458
Z-2.8918 C-188.77
Z-2.9003 C-185.931
Z-2.9054 C-182.991
Z-2.9071 C-180.
Z-2.9054 C-177.009
Z-2.9003 C-174.07
Z-2.8918 C-171.231
Z-2.8803 C-168.543
Z-2.8657 C-166.051
Z-2.8485 C-163.797
Z-2.1414 C-82.766
Z-2.1217 C-80.793
Z-2.1 C-79.128 F1688.14
Z-2.0765 C-77.802 F1314.18
Z-2.0518 C-76.839 F938.48
Z-2.0261 C-76.254 F562.76
Z-2. C-76.058 F187.51
Z-1.9739 C-76.254
Z-1.9482 C-76.839 F562.76
Z-1.9235 C-77.802 F938.48
Z-1.9 C-79.128 F1314.18
Z-1.8783 C-80.793 F1688.14
G0 X1.5 C-82.766
Z-2.3605 C-179.979
X1.2
G1 X.95 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.9 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.85 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
X.8 F7.
Z-2.0004 C-221.408
Z-1.9998 C-221.482
Z-1.9816 C-219.525
Z-1.6411 C-180.293
Z-1.639 C-180.039
Z-1.9756 C-141.43
Z-1.9995 C-138.596
Z-2.0002 C-138.515
Z-2.0174 C-140.358
Z-2.3605 C-179.979
G0 X1.5
Z0.200
M9
M50 ; Turn C-axis off
M25 ; Turn Live tooling off
G28 T0100
Re: C Axis Lathe Situation
i moved this post into the acorn forum
From C-100 to C-200 is one direction, from C-200 to C-100 the other direction
The direction is determined by increasing or decreasing the C-axis value, no matter if the code starts at C0 or C-75
