hi,
has anyone experience with the HAK31 Tool Turret for lathes ? My Lathe is roughly running now and i plan to have a tool turret in further steps, maybe in half a year. i had a look on these turrets since more than one year. now i found this offer, the price is really good, better than ever seen before in the last year.
https://de.aliexpress.com/item/10050061 ... ry_from%3A
i have the datasheet from the seller, attached.
but i had no time before to check and learn how a tool turret is implemented in AcornSix. can anybody have a look to the datasheet and tell me, if this turret works with Acorn ? What do i need ? Ultimate Licence is available,
i understand the principal logic, but for the details i need help.
thank you a lot in advance.
best regards,
Michael
HAK31 Tool Turret Lathe
- CNC Control System Serial Number: 0008DC111213-1005220061
- HAK31_HAK34_NC_Turret_Manual_For_Use_And_Maintenance.pdf
- (1.89 MiB) Downloaded 10 times
Re: HAK31 Tool Turret Lathe
this turret looks pretty typical
Acorn and AcornSix have preprogrammed typical setups for common turret configurations.
you can start with one of those and modify to your needs.
okay, thank you a lot.
i had a deeper look to the Centroid ATC Folder with the different Grey-Codes and from principal function i understand that. but right now i would have no idea how to connect the turret to the Acorn6 board.
when i look in the data-sheet, i see those three pictures regarding the wiring:
Signal port should be almost clear
but with these both i am not sure how to handle them. can i choose on of theese ? can i choose if the control need encoder signal or Hall-Sensor signal ?in the grey-code folder i found two variants with encoder wiring, that makes sense to me.
thank you a lot
Michael
thank you a lot
Michael
for the Acorn side of things, search "turret" here and you will find typical hookups for common turrets for Acorn
https://www.centroidcnc.com/centroid_di ... browse.php#
like this one
https://www.centroidcnc.com/dealersuppo ... 006.r2.pdf
like this one
