Homing 4th Axis
guerra_cues
CNC Control System Serial Number: 0035FF98CA2D-0813215079
Re: Homing 4th Axis
Post by guerra_cues »
Sword wrote: Wed Mar 13, 2024 9:53 pm How much gap is there between the proxy and the bolt? You might need to close the gap a bit more. Also, try a flatter hex head bolt with a bit of a radius groeund on it. It might sense better.
Your cncm.hom file doesn't have the home command for the 4th yet. Once you set the direction for the 4th, set "wizard to create" and then write the settings.
You can check the proxy by watching the input in the diagnostic screen while spinning the axis with the arrow keys.
Cross posted with cncsnw. ;)
I have attached the latest report and have change now to Wizard to generate automatic home program. The bolt is very close to the proxy, maybe 0.200" or less and when the bolt passes the proxy, the light on the proxy turns off and then back on again.
I have set the home for the A axis right on the bolt and proxy meet each other. But when I home the CNC (pressing PARK button) the A axis does not stop where the proxy meets the bolt, it bypasses it.
However I have more serious issue now (to me) because I am unable to home the CNC. I have a Home switch tripped and I am unable to home and use the cnc.
I have posted the latest report and PLC screenshot. HELP please :oops:
cncsnw wrote: Wed Mar 13, 2024 9:47 pm Your cncm.hom file has only an M26 for the A axis. It has no M92 to move it to its switch.
You have correctly indicated that INP6 is a fourth axis home switch, and it shows up in your Machine Configuration -> Motor Parameters table as such.
You have correctly indicated that you want to home your A axis in the positive direction.
However, you have selected "I will create my own home program ...". This prevents the Wizard from changing your cncm.hom file to match your selections. You either need to select "Wizard to generate automatic home program ...", or you need to edit the M92/A code into cncm.hom yourself.
report_0035FF98CA2D-0813215079_2024-03-13_21-27-18.zip
(801.1 KiB) Downloaded 4 times
Tony Maninha
www.facebook.com/guerracues
Using Centroid Acorn Router "Pro" CNC12
Re: Homing 4th Axis
Jog the A axis until INP6 is green. Then press Cycle Start to find home.
guerra_cues
Re: Homing 4th Axis
cncsnw wrote: Thu Mar 14, 2024 2:52 am Jog the A axis until INP6 is green. Then press Cycle Start to find home.
Yeah! It works! Thank you!
Let me bring up another issue...
I am having somewhat of a loud pitch noise On the Z axis depending on what position is it on... Any ideas about what the issue might be and how can I troubleshoot it?
Tony Maninha
Re: Homing 4th Axis
does the noise happen when the axis is moving or holding position?
and remind us what kind of axis motor and drive do you have?
a lot of axis motors will make noise when holding if there is play in the mechanical system or too tight! so look for either in the Z axis mechanism
guerra_cues
Re: Homing 4th Axis
cnckeith wrote: Thu Mar 14, 2024 1:46 pm does the noise happen when the axis is moving or holding position?
Noise happens when the Z axis moves and even holding position, if I move a few thousands the noise goes away actually. I am using Clearpath motors.
I might do a video to give a better idea of what is going on.
Tony Maninha
Re: Homing 4th Axis
ok does the noise come from the motors themselves? if so, sounds like you need to tune them.
a video of it would be great so we can hear what kind of noise it is.
guerra_cues
Re: Homing 4th Axis
cnckeith wrote: Thu Mar 14, 2024 2:07 pm ok does the noise come from the motors themselves? if so, sounds like you need to tune them.
I will try to do a video later on today. Thanks again.
Tony Maninha
guerra_cues
Re: Homing 4th Axis
Just recorded this with my GoPro. The noise stops when I move a few thousands of an inch up and down on the Z. I hope it makes sense about the noise I was complaining about, excuse the dust, this CNC is not a workbench queen 🤣 :
Tony Maninha
guerra_cues
Re: Homing 4th Axis
Problem solved. I little bit of grease to pump out any debris out the ball nut solved the problem. Learning as I go…
Thanks guys!
Tony Maninha
